purpose of bolt hole? - Ford Truck Enthusiasts Forums
Old 12-03-2013, 11:12 AM
unibody62's Avatar
unibody62 unibody62 is online now
unibody62 is starting off with a positive reputation.
I guess I didn't take very good pictures when dismantling my 1962 292, because I can't find out what bolts into these holes in the heads.
empty - a set on Flickr
They are all the way to the back and not covered by the intake. For now, I just plugged them with short bolts, but I was thinking that at least one of them would be used for a ground wire. Is that correct, or is there another purpose?
Old 12-03-2013, 01:43 PM
Y-Blockhead's Avatar
Y-Blockhead Y-Blockhead is offline
Y-Blockhead is starting off with a positive reputation.
If you look at the heads they can be installed on either side. If you had swapped heads that bolt hole would correspond to the front intake bolt hole by the water passage.
That said you did the right thing by plugging them or oil would come out of them when you start the engine. They are open to the back pushrod passages as you can see in your first photo.
Just be sure they are short (~1/2") because if too long could hit the pushrod and bend it.
I believe the plug wire loom bolts to the passenger side one. The drivers side I do have a body ground bolted there.
Old 12-05-2013, 10:35 AM
unibody62's Avatar
Thanks for your answer. Pretty much what I figured, but just wanted to verify with others. I used 3/4 in bolts, and they look like they clear by the time you add a washer and maybe another attachment in there.
Old 04-27-2014, 09:36 PM
Outlaw56 Outlaw56 is offline
Outlaw56 is starting off with a positive reputation.
Thats so funny, just found the same two holes on mine and was wondering what they were for.
Tate's 72 Highboy Restoration. tpdaniels 1967 - 1972 F-100 & Larger F-Series Trucks 92 12-23-2016 09:56 PM
Front axle complete seal replacement aldridgec 1999 to 2016 Super Duty 43 11-27-2016 05:47 PM
Unibody frame swap Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 3 06-26-2014 12:04 AM
Windshield frame rust from leaky seal bigzirb Excursion - King of SUVs 18 04-15-2014 09:19 PM
Can anyone tell me ? Have you ever seen one? chadbob 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 03-31-2014 03:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
