Would I need a front end level kit for this?
I'm considering getting some new wheels and tires for my truck. The stock wheels are the 20" wheels and 275/55/20 tires. If I get new 20x9 (XD Rockstar II) wheels and same OEM size tire 275/55/20 (e.g. Nitto Terra Grapplers) would I need to add a level kit for rubbing?
Thanks
Thanks
Im assuming you mean on the '12 F150 in your sig. If that is the size that came on it from the factory you should have no issues. But just to be sure, Turn your tire to full lock in both directions and just look and see how much clearance you have, the tire is gonna now be a little wider and offset a bit more. Id think that it prolly be somewhere around 1.5-2" more offset (assume factory wheels are 20x8)
Received 3,105 Likes
on
on
Also found a millimeter to inches conversion calculator so that you can tell how far out of the wheel wells your new tires will be. https://www.google.com/search?q=mill...sm=93&ie=UTF-8
link to see your truck with a level kit (give it a second or two to load): http://tbcwheels.ridestyler.com/?mode=webbot#
I've now got a much better idea of offset and sizing issues. Thanks so much y'all!
hdroadking05
1999 to 2016 Super Duty
12-18-2007 01:15 PM
