Intercooler install
That looks really good! I would be really interested to hear exactly what you added to the SD pipes to make them work for this application. I picked up a set of pipes and a spyder a couple weeks ago for this install at some point. My trouble is that the pipes I found were aluminum. I'm not above scrapping them completely and building my own plumbing, but if the modifications to the pipes aren't that bad, I may just buy some tubing and bends and get it all TIG welded up.
https://www.ford-trucks.com/forums/9...installed.html
That looks like a grade A job to me. The passenger side pipe looks factory, and the drivers side looks very good too. It would look factory too if the SD dent wasn't in the pipe. I hope to do this sometime.
You definately need to look into an intake updrade. My advice is, "Do not buy an K&N!" There are so many better options.
The truck is your signature looks wicked bad too!
golfmedik
6.7L Power Stroke Diesel
74
01-14-2019 04:24 PM
Chris56ford
21
08-09-2014 09:43 AM
powerstroke8994
10-12-2009 01:25 PM
