Intercooler install - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Intercooler install
Old 12-05-2013, 10:36 AM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is online now
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Wink
Quote:
Originally Posted by DIYMechanic View Post
That looks really good! I would be really interested to hear exactly what you added to the SD pipes to make them work for this application. I picked up a set of pipes and a spyder a couple weeks ago for this install at some point. My trouble is that the pipes I found were aluminum. I'm not above scrapping them completely and building my own plumbing, but if the modifications to the pipes aren't that bad, I may just buy some tubing and bends and get it all TIG welded up.
Nate, you can do what I did:
http://www.ford-trucks.com/forums/98...installed.html
Old 12-05-2013, 12:51 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.
That looks like a grade A job to me. The passenger side pipe looks factory, and the drivers side looks very good too. It would look factory too if the SD dent wasn't in the pipe. I hope to do this sometime.
You definately need to look into an intake updrade. My advice is, "Do not buy an K&N!" There are so many better options.
The truck is your signature looks wicked bad too!
Old 12-05-2013, 01:12 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Wink
yes I agree, and been there, also change that orange boot for one aftermaket like RiffRaf: http://www.riffraffdiesel.com/riffra...o-intake-boot/
Old 12-06-2013, 07:34 PM
davewild's Avatar
davewild davewild is offline
davewild is starting off with a positive reputation.
Yeah I might do something about that dent at some point. Maybe re-work the intake then fix the dent.
Old 12-06-2013, 08:36 PM
Got4wd Got4wd is offline
Got4wd is starting off with a positive reputation.
Quote:
You can always use the water and freeze trick. Lots of motorcycle guys use it when they sent their pipes.
Lowering my 78' F150 and Crown Vic suspension swap davewild 1973 - 1979 F-100 & Larger F-Series Trucks 316 01-10-2017 11:40 AM
Explorer disc brake conversion davewild 1973 - 1979 F-100 & Larger F-Series Trucks 25 12-13-2015 01:44 PM
Off topic (again) willowbilly3 1947 and Older Ford Trucks 8 10-19-2015 10:42 PM
Nice day for a cruise (pics) willowbilly3 1947 and Older Ford Trucks 8 09-30-2015 11:50 PM
Pictures of the 60 willowbilly3 1957 - 1960 F100 & Larger F-Series Trucks 9 03-31-2015 04:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
