WMO/clean unused oil ... - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 07-27-2014, 10:01 PM
speedwrench72's Avatar
speedwrench72 speedwrench72 is offline
speedwrench72 is starting off with a positive reputation.
I would stay away from acetone as it swells nitrile seals and may damage fuel pump diaphrams. IMO that the slower longer burn is also quieter and when my bro ran some of my blend in his rig, he saw a little higher egt's so that might prove more power but with nothing but a butt dino can't know for Shure.
  #32
Old 03-24-2016, 08:41 PM
Jaime74656's Avatar
Jaime74656 Jaime74656 is offline
Jim
Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.
I typically run and, oil here truck is happy as can be
  #33
Old 06-05-2016, 11:32 PM
SpencerS's Avatar
SpencerS SpencerS is offline
SpencerS is starting off with a positive reputation.
i was thinking about getting one of these and then running as high of a percentage of WMO as i can in my 6.9:
Compact Black Diesel Processor No Bucket
  #34
Old 06-06-2016, 10:14 PM
Macrobb's Avatar
Macrobb Macrobb is offline
Macrobb is gaining momentum as a positive member of FTE.
I would get a centrifuge. High-PSI(~1800 for the 6.9) injection pumps do not like metal shavings and particles and will wear quickly.
If you spend the money on a centrifuge and get all the crud out, the IP and injectors should last a *lot* longer.
Also, the solenoids inside the DB2 pumps will attract metal shavings on the /return/ side of the pump, and can make them fail or jam. I've heard of them being covered in shavings from running (improperly filtered) WMO.
WMO ideas? 10thMountainMechanic Bio-diesel, Propane & Alternative Diesel Engine Fuels 28 09-08-2014 06:27 PM
Looking for waste oil WMO near Atlanta, Ga ninegeorge Bio-diesel, Propane & Alternative Diesel Engine Fuels 1 06-28-2014 01:23 PM
new to WMO joshofalltrades Bio-diesel, Propane & Alternative Diesel Engine Fuels 51 03-03-2013 01:21 AM
HELP! WMO Excessive smoke! 7.3 IDI Allen72289 Bio-diesel, Propane & Alternative Diesel Engine Fuels 5 03-01-2011 03:21 PM
WMO, WVO,diesel mixable? '88 E-350 Bio-diesel, Propane & Alternative Diesel Engine Fuels 45 12-16-2010 09:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
