TPS troubles - Ford Truck Enthusiasts Forums
TPS troubles
Old 12-02-2013, 10:54 PM
Forddiesel17's Avatar
Forddiesel17 Forddiesel17 is offline
Forddiesel17 is starting off with a positive reputation.
TPS troubles
I just replaced the ip in my dads 94 and started to adjust the tps and I can't get the voltages anywhere near close enough. It is a brand new tps. I have 4.99 volts to the constant wire but the center I can only get .44 volts at idle and the most I ever got was .70 at WOT. I'm starting to wonder if I have the adapter that you put on the throttle shaft is in the wrong position. Does it go on a certain way? Thanks in advance guys!
Old 12-03-2013, 12:25 PM
Anyone? Gotta get this truck running as it's my dads snow plow truck.
Old 12-03-2013, 01:03 PM
Prototypemech's Avatar
Prototypemech Prototypemech is offline
Prototypemech is starting off with a positive reputation.
Did you buy the Sensor from autozone/duralast? If so, return it! I'm replacing a TPS sensor today. I've read that the connector terminals has a tendency to spread out and stop making a good contact against the TPS. The connector can be taken apart and the terminals squeezed back together with some pliers. Napa sells just the TPS pig-tail if it needs to be replaced. The only other thing is to make sure your Multimeter has a good ground and that youre back-probing is successful.
Old 12-03-2013, 01:08 PM
fhafer's Avatar
fhafer fhafer is offline
fhafer is starting off with a positive reputation.
And make sure your IP has the adapter on the throttle shaft. Without that you won't get any change in voltage readings...as I found out and posted about yesterday.
Good luck.
P.S. O'Reilly's sells the TPS connector for eight bucks if'n your pig tail is bad.
Old 12-03-2013, 01:56 PM
Does that adapter go in a certain way? I didn't pay attention when I took it off. And I got the tps from napa but maybe it is bad out of the box. I might try the old one and see what it does.
Old 12-03-2013, 03:07 PM
I didnt take off the adapter, I simply removed the 2 t-15 torq screws. I do have some specs for you based on my new NAPA sensor. Between terminal A and B, there should be 380 ohms when the sensor is relaxed. When you twist the potentiometer, the resistance should rise to 3.5K ohms. I think your sensor is fine and you just have it clocked wrong. Heres how I clocked mine; Install the sensor into the bracket/adapter with the connector at the 12 oclock position. Then rotate the sensor counter-clockwise til you feel the potentiometer begin to wind up. The TPS connector was at the 9 o'clock position on my engine. The screw holes should be pretty close. Install the screws and check the voltage with your multimeter. If its not close, loosen up the t-27 torq screws on the pump and adjust the bracket.
Old 12-03-2013, 06:07 PM
Well the pump shop took off the adapter with the flat spot on it off the shaft when they rebuilt it but didn't mark where it was and I didn't think to mark it. What position is that adapter on your truck?
Old 12-03-2013, 07:14 PM
The set screws are at the 9 o'clock and 12 o'clock position at idle.
Old 12-03-2013, 07:16 PM
Ok thanks! That should help me out a lot. I don't have a chance to work on it tonight but should by the weekend. If I got more trouble I will be sure to post. Thanks for your help so far!
Old 12-03-2013, 07:59 PM
fhafer's Avatar
A picture is worth a thousand words...
IPtoTPSAdapter.jpg Photo by fhafer1964 | Photobucket
Hope this helps!
Cheers
Old 12-04-2013, 05:27 PM
srqdiesel chef's Avatar
srqdiesel chef srqdiesel chef is offline
srqdiesel chef is starting off with a positive reputation.
I'm not sure if my memory is working. bit iirc there is a little pinkish plastic piece under that adapter and if that is positioned wrong you will never get the right settings. anybody else remember this? if I can I will look on my truck later and try to post pics
TPS Code andyj93f150 Performance & General Engine Building 3 09-10-2015 08:37 AM
Code 23 TPS help vtjvt 1987 - 1996 F150 & Larger F-Series Trucks 0 06-04-2014 10:58 PM
TPS wont stay at 1v Chefsteele 1987 - 1996 F150 & Larger F-Series Trucks 168 12-18-2013 11:29 PM
1986 302 tps help melvinew2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 11-20-2013 07:47 AM
High Idle problem mike24150 1987 - 1996 F150 & Larger F-Series Trucks 10 07-05-2013 02:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
