Spacers, bungs, crush tubes, and hardpoints. Oh my!
DOM tubing is very nice material, but kinda pricy for cutting up for bungs especially if you need thick wall and have to meet a suppliers min purchase (often a 20' length of each size) Horton also has what he calls weld nuts that are inexpensive on pg 53 of his downloadable catalog that would be good to use instead of a welded on hex nut:
http://www.welderseries.com/hardcopy/weldercat.pdf
Ax, you are not only well versed in fabrication and truck restoration, but you have a great command of the English language. I think I installed a couple of bungs, or spacers in my winch install last week. Part of my winch mount was bolted through square tubing, so I cut some 1/2" black pipe and drove them inside to keep it from collapsing. I didn't know they had a name. Hey, maybe they were crush tubes. .....
Great info! Thank you for sharing. It is great to continue learning. I was aware of hard points but not the terminology.
I just added some bungs to support my steering shaft. Had to snake it around the exhaust manifold and also built a "shorty" column inside so I could mount the steering wheel more vertical than horizontal.
I guess I'm a resto-mod fan
Note, when I took the picture, I hadn't yet finish welded the forward bung. It was just tacked.
Hope I'm not junking up your thread with my pictures / posts.
Cheers,
Doug
Cheers,
Doug
hjartland
07-12-2018 04:17 PM
BlueOvalRage
11-25-2016 07:22 AM
f1fordguy
12-17-2004 11:39 AM
