Power steering part
Power steering part
Hi there
I am in Australia and have a rather large problem. My 82 f100 needs another "short sector shaft" for the power steering box...only problem is that there are Zero available here. I don't know if the box in it, is the same as an 82 truck in the US. I'm hoping.
Can I source one from a supplier over there and if so, who? This is a regularly used truck and without this repair I don't have a vehicle!
Thank you
Thank you
Here in the states, the ford ranger used the same steering gear box as the F series trucks. As long as both are twin I-beam/TTB, they interchange. Did you guys get the smaller trucks prior to 98? 97 was the last year either of these were sold here with the TIB/TTB suspension setup.
Just a thought that could open up a few sources for the needed parts.
Just guessing here, but the guts may be the same, the outside casting would definitely be different I suppose, so it could mount to the other frame rail.
james gang 1001
02-25-2010 10:47 AM
bodysaffa
04-04-2002 11:15 AM
