Just Bought 97 F350 Crew Cab
12-02-2013, 09:05 PM
Saty away from the EDGE chip with your auto trans. Stick trans are fine
12-03-2013, 09:15 PM
I just looked at the door sticker and it shows an axle code of C5
12-03-2013, 09:50 PM
12-03-2013, 10:02 PM
is there a way to tell how good of shape the slip clutches are in, and if they are in bad shape are they rebuildable?
12-06-2013, 08:23 PM
12-06-2013, 08:40 PM
Quote:
Originally Posted by
1994F2507.3L
If the clutches are good then there will be no slipping.
If they rate bad, it will slip and you need NEW clutches along with a bunch of other parts
12-06-2013, 08:44 PM
Jack it up.try to turn one tire..if you can turn one and the opposite rotates the opposite way its worn..mine I could not rotate , its good.yes the clutches are replaceble to bring a worn one back.there is a brake away torque value to gauge the bias but I cant remember the spec.you will know if its good or bad.not much inbetween.
12-07-2013, 05:33 AM
My bad. issued the part about the Limited slip clutches. I though he was talking trans
12-07-2013, 10:29 AM
Where do you get the replacement clutches from?
12-10-2013, 06:43 PM
Do you have any pics of your new truck?, because the original link has been deleted
Welcome to this psd forum.
PS, I cant help you with the clutches, but this is a bump for you.
12-10-2013, 08:19 PM
Randys ring and pinion or drivetrain usa
Big red_11
16
01-14-2015 12:51 PM
sand1
07-14-2014 07:25 PM
Orr353
06-08-2010 10:47 AM
SuperDutyF250
11-21-2005 09:19 PM
wylie_psd
Computer Chips & Tuners
10-26-2005 08:32 PM
