Another romps on start up thread
12-01-2013, 08:59 AM
on
My 95 romps every time I start doesn't matter if it's hot or cold, or if the icp is plugged in or not. It goes away after holding the throttle at 1200 rpm for about 10 seconds. The truck runs pretty good. Is it possible it just doesn't like the delo oil?
12-01-2013, 10:03 AM
If its a auto try starting in "N" if the romps go away then your MLPS is bad
12-01-2013, 10:04 AM
Never mind I just noticed it was a ZF5
How old is the oil?
How is the oil level ?
12-01-2013, 11:05 AM
on
Maybe 500 miles on oil and it's full
12-01-2013, 11:10 AM
Does it fire right up or is there an extended cranking time ?
12-01-2013, 11:25 AM
on
It takes a sec. But I think is glow plug related I've been waiting to tear into it until I get sd style uvch parts I'll check the hpop resivor
12-01-2013, 02:58 PM
on
12-01-2013, 03:49 PM
on
12-01-2013, 03:59 PM
on
Cranks fast 2 new batteries
12-04-2013, 05:55 PM
on
12-04-2013, 05:59 PM
on
Injectors are tired.
That how I switch to 5w40 FULL Synth it work for me in winter time.
12-04-2013, 06:51 PM
on
Injectors might have 5k miles on then they are reman rosewood 160/30
12-04-2013, 08:41 PM
Did this start after an oil change ?
Did you swap oils ?
12-04-2013, 09:24 PM
on
Yes it started after a oil change but it was the first oil change I have done on it since I bought it in June. I do not know the type of oil it had but I'd guess rotella and it has delo now
12-05-2013, 09:01 AM
May want to make sure the by pass valve is in place
