Another romps on start up thread
Old 12-01-2013, 08:59 AM
arkredneck's Avatar
arkredneck
arkredneck is offline
My 95 romps every time I start doesn't matter if it's hot or cold, or if the icp is plugged in or not. It goes away after holding the throttle at 1200 rpm for about 10 seconds. The truck runs pretty good. Is it possible it just doesn't like the delo oil?
Old 12-01-2013, 10:03 AM
fordpride's Avatar
fordpride
fordpride is offline
If its a auto try starting in "N" if the romps go away then your MLPS is bad
Old 12-01-2013, 10:04 AM
fordpride's Avatar
fordpride
Never mind I just noticed it was a ZF5
How old is the oil?
How is the oil level ?
Old 12-01-2013, 11:05 AM
arkredneck's Avatar
arkredneck
Maybe 500 miles on oil and it's full
Old 12-01-2013, 11:10 AM
fordpride's Avatar
fordpride
Does it fire right up or is there an extended cranking time ?
Old 12-01-2013, 11:25 AM
arkredneck's Avatar
arkredneck
It takes a sec. But I think is glow plug related I've been waiting to tear into it until I get sd style uvch parts I'll check the hpop resivor
Old 12-01-2013, 02:58 PM
arkredneck's Avatar
arkredneck
Hpop resivor is full
Old 12-01-2013, 03:49 PM
osu711's Avatar
osu711
osu711 is offline
How does it crank? slow?
Old 12-01-2013, 03:59 PM
arkredneck's Avatar
arkredneck
Cranks fast 2 new batteries
Old 12-04-2013, 05:55 PM
arkredneck's Avatar
arkredneck
Any ideas anyone?
Old 12-04-2013, 05:59 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
Milwaukee1979F150 is offline
Injectors are tired.
That how I switch to 5w40 FULL Synth it work for me in winter time.
Old 12-04-2013, 06:51 PM
arkredneck's Avatar
arkredneck
Injectors might have 5k miles on then they are reman rosewood 160/30
Old 12-04-2013, 08:41 PM
fordpride's Avatar
fordpride
Did this start after an oil change ?
Did you swap oils ?
Old 12-04-2013, 09:24 PM
arkredneck's Avatar
arkredneck
Yes it started after a oil change but it was the first oil change I have done on it since I bought it in June. I do not know the type of oil it had but I'd guess rotella and it has delo now
Old 12-05-2013, 09:01 AM
Action4478's Avatar
Action4478
Action4478 is offline
May want to make sure the by pass valve is in place
Quick Reply: Another romps on start up thread
