Another romps on start up thread - Ford Truck Enthusiasts Forums
Old 12-01-2013, 08:59 AM
arkredneck's Avatar
arkredneck arkredneck is offline
arkredneck is starting off with a positive reputation.
My 95 romps every time I start doesn't matter if it's hot or cold, or if the icp is plugged in or not. It goes away after holding the throttle at 1200 rpm for about 10 seconds. The truck runs pretty good. Is it possible it just doesn't like the delo oil?
Old 12-01-2013, 10:03 AM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
If its a auto try starting in "N" if the romps go away then your MLPS is bad
Old 12-01-2013, 10:04 AM
fordpride's Avatar
Never mind I just noticed it was a ZF5
How old is the oil?
How is the oil level ?
Old 12-01-2013, 11:05 AM
arkredneck's Avatar
Maybe 500 miles on oil and it's full
Old 12-01-2013, 11:10 AM
fordpride's Avatar
Does it fire right up or is there an extended cranking time ?
Old 12-01-2013, 11:25 AM
arkredneck's Avatar
It takes a sec. But I think is glow plug related I've been waiting to tear into it until I get sd style uvch parts I'll check the hpop resivor
Old 12-01-2013, 02:58 PM
arkredneck's Avatar
Hpop resivor is full
Old 12-01-2013, 03:49 PM
osu711 osu711 is offline
osu711 is starting off with a positive reputation.
How does it crank? slow?
Old 12-01-2013, 03:59 PM
arkredneck's Avatar
Cranks fast 2 new batteries
Old 12-04-2013, 05:55 PM
arkredneck's Avatar
Any ideas anyone?
Old 12-04-2013, 05:59 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150 Milwaukee1979F150 is offline
Milwaukee1979F150 is gaining momentum as a positive member of FTE.
Injectors are tired.
That how I switch to 5w40 FULL Synth it work for me in winter time.
Old 12-04-2013, 06:51 PM
arkredneck's Avatar
Injectors might have 5k miles on then they are reman rosewood 160/30
Old 12-04-2013, 08:41 PM
fordpride's Avatar
Did this start after an oil change ?
Did you swap oils ?
Old 12-04-2013, 09:24 PM
arkredneck's Avatar
Yes it started after a oil change but it was the first oil change I have done on it since I bought it in June. I do not know the type of oil it had but I'd guess rotella and it has delo now
Old 12-05-2013, 09:01 AM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
May want to make sure the by pass valve is in place
Rotella 15w40 to mobile 1 5w40 tdt Dude-Ford 1999 - 2003 7.3L Power Stroke Diesel 17 01-16-2017 10:29 AM
Injector question jbounds 1999 - 2003 7.3L Power Stroke Diesel 11 01-07-2016 04:26 PM
96 CCLB auto with a nasty romp after 5 minutes of idling nossliw 1994.5 - 1997 7.3L Power Stroke Diesel 29 02-23-2015 12:56 PM
cold skip?? scottma978 1999 - 2003 7.3L Power Stroke Diesel 6 05-21-2006 08:15 PM
ROMP-ROMP and die on warm startups ChevDog1 1999 - 2003 7.3L Power Stroke Diesel 16 09-07-2004 03:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
