I'm trying to find out what I need to check or replace to get my 2000 Excursion to idle at normal rpm's in park and neutral. Any suggestions would be appreciated.
It looks like the Idle Control Valve...... I had a 2000 and it did the same thing. I changed it and it went back to normal. My ICV was full of carbon. My 2004 is starting to do it too so I might go get one soon....
pita = Pain in the azz..... I think you can try to clean it and see what happens, Use carb cleaner.... I might try that first on mine instead of spending $60.... im a big cheapskate....
