What's the best place/site to get v10 tune up kit
I have a 1999 f250 triton v10 and I wanna do a full tune up on the motor. ( coil plugs, spark plugs, coil boots, etc) where's the best place or site to get the stuff .... That has good quality. I don't care if its a tune up kit or getting everything seperit
I was looking at these Ford 4 6L 5 4L 6 8L V8 V10 Engine Complete Set of 10 Ignition Coils DG508 DG491 | eBay
Boots, springs and plugs need to be replaced. Use motorcraft parts only. As far as the coil packs go I would wait and if you get a misfire change that coil pack only. Most of the parts can be had at a local auto parts store or rockauto. Not sure if you have but may want to change the pcv valve and fuel filter at the same time.
I only use motorcraft on mine too. Advance auto here sells the coils for $10 less per coil than the ford dealer. Plugs were a little less too, but only about 50 cents per plug. I would only replace coils as they go bad too. They either work or they don't and no point in replacing something that isn't bad.
72soa
03-02-2008 02:26 PM
