C3M?? block casting ID help
Old 11-30-2013, 01:16 PM
No More Raptor's Avatar
No More Raptor
No More Raptor is offline
Just picked up a engine and am wondering what exactly it is?
Block cast is c 3 or 8 m and the rest I cant tell. the date code is 5d18
crank is c4ae-b also has a 1 and a Z
rods are c3ae-c
pistons c3me6110a
heads c4ae 6090-g with matching date codes 5D15
any help would be appreciated
Thanks
Old 11-30-2013, 05:29 PM
FFR428's Avatar
FFR428
FFR428 is offline
Needsmorecoffee.
It's a 390. Seems original too. Nice. 65 vintage. Block 5D18 is 65 April 18, heads are from the 15th. C4AE-B crank a 390.
Old 11-30-2013, 08:17 PM
No More Raptor
Can you tell about the pistons?
Old 11-30-2013, 10:12 PM
baddad457's Avatar
baddad457
baddad457 is offline
Ford pistons sometimes had the displacement cast into them near the pin holes. A quick check with a dial caliper will tell you the diameter. You already know the stroke with a C4AE crank. A C3 block I would think would have two mount holes per side. But I could be wrong on that.
Old 12-01-2013, 05:31 AM
No More Raptor
The motor mounts have 3 bolts. The block casting
Is poor and hard to read. The first letter is C 2nd could be a 3 but it's messed up
3rd is clearly an M the rest is a mess. It's not important though
It's a nice 390 that's all that matters. I was just
Wondering about pistons and CR of them.
Thanks for all your help
here is the piston.....
Anyone in New Jersey of New York that can recommend a real deal FE builder?
Old 12-01-2013, 12:55 PM
baddad457's Avatar
baddad457
More'n likely that's a C6ME-A block. Never seen one that bad on the outside though. As such, I doubt it's an untouched assembly with those heads, crank, rods and a C6ME-A block. But you never know with Ford. Clean the piston top off and see if there's an overbore stamped into it. Looks like a std 9 to 1 piston though. The early 10.5 to 1's had a shallower dish and no valve reliefs.
Old 12-01-2013, 02:26 PM
No More Raptor
found this little pad with numbers stamped into it right next to the dipstick tube-
2-17 4
Old 12-01-2013, 02:39 PM
No More Raptor
better pic of block cast
Old 12-02-2013, 11:53 AM
baddad457's Avatar
baddad457
Still looks like a "6" to me. Could be an "8" but that would denote a 428CJ block. Pop the center core plug out and see if there's a "428" cast into the bore wall.
Old 12-02-2013, 12:25 PM
No More Raptor
I dont think its possible to be a 428 with a date code of 5D18 ???
Old 12-02-2013, 03:39 PM
baddad457's Avatar
baddad457
Yea, hadn't thought of that. Measuring the piston at the skirts will give you the diameter, but it's got to be a 390 with that crank.
Old 12-02-2013, 06:49 PM
No More Raptor
I found this info on FE Info site, FE INFO
Not drilled, do the markings mean anything?
Old 12-03-2013, 12:11 PM
baddad457's Avatar
baddad457
What's not drilled ? What markings ?
Old 12-03-2013, 02:26 PM
FordmanShane's Avatar
FordmanShane
FordmanShane is offline
Are you talking about the little freeze plugs? its drilled and hydraulic.. I think those markings are nothing.. it would look like a C was welded to the back.. not.. crayola..
mtdorf
08-13-2013 08:30 PM
OldFordRacer
10-27-2007 10:26 PM
orangeconv
23
02-11-2005 07:06 AM
fordmann
02-23-2003 05:12 AM
67 428 Fairlane Ranchero
13
01-14-2003 10:43 AM
Quick Reply: C3M?? block casting ID help
