Flex plate 97 4.0 - Ford Truck Enthusiasts Forums
Flex plate 97 4.0
Old 11-30-2013, 11:03 AM
ltlvt ltlvt is offline
ltlvt is starting off with a positive reputation.
Question Flex plate 97 4.0
I have a 97 4.0 pushrod motor with the 8 bolt crank and 8 bolt flex plate. The bolt holes appear to be equally spaced. How do you make sure the flex plate is in the correct position to the crankshaft if they have been separated and not marked? I've already put the engine in the truck and it runs fine but seems to have a shake when driving over about 45 mph. I've changed all u joints the carrier bearing new brakes /calipers/rotors/wheel cylinders/shoes etc. Also has new tires and wheels and old tires and wheels did the same thing. Thanks Terry
Frame/Str. box Flex F-250 restorer 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-25-2015 10:12 PM
Rattle from near flex plate? Nothing Special 1987 - 1996 F150 & Larger F-Series Trucks 5 09-19-2014 12:55 PM
1994 F-250 E4OD interchange musicars Clutch, Transmission, Differential, Axle & Transfer Case 3 07-10-2014 01:24 AM
98 f 150 4.6l with 4r70w trans keeps breaking flexplates roughneck621 1997 - 2003 F150 3 12-03-2013 11:06 PM
E4OD swap flex plate question Ongoingshow 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-13-2011 05:36 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
