Regen frequency - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Regen frequency
Old 12-17-2013, 04:30 PM
aquaman aquaman is offline
aquaman is gaining momentum as a positive member of FTE.aquaman is gaining momentum as a positive member of FTE.
A cracked DPF is a blessing :-)
Old 01-10-2014, 08:15 PM
09powerstroke's Avatar
09powerstroke 09powerstroke is offline
09powerstroke is starting off with a positive reputation.
Took care of the issue, just put a H&S mini maxx and a flo-pro exhaust on, and deleted the DPF and EGR.
Old 01-12-2014, 10:52 AM
jlrFordFan jlrFordFan is offline
jlrFordFan is starting off with a positive reputation.
180 - 225 miles between regens. Duration of the regen averages 20 miles, and by my rough (very rough) calculations consumes 2 gals of fuel to get the job done.
As perfectly described above the distance between regens will shorten up considerably if you do a lot of idling. I've read that it is less damaging to these engines if you stop and start the engine more frequently rather than allowing to idle.
Old 01-12-2014, 12:16 PM
Yep, I'm also calculating between 1-2 gallons of fuel for a full regen with the lesser amount of fuel used during the hotter summer months on straight freeway. Overall it's looking like a 5-7% impact on fuel economy...more if idling a lot.
I wonder how the 6.7 fares...
Truck not regenerating ehaust CornTruckDriver 6.7L Power Stroke Diesel 7 09-08-2015 07:55 PM
Regens and economy Ricohman 6.7L Power Stroke Diesel 5 08-11-2015 10:44 AM
Ugh! Too Many Active Regens! rmrichards949 6.7L Power Stroke Diesel 66 07-25-2013 03:40 PM
Regen jam105 6.4L Power Stroke Diesel 7 01-21-2011 09:17 PM
Overactive re-gen and no dealer help PHXDiesel 6.4L Power Stroke Diesel 32 10-04-2008 09:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
