Hauling wood pellets:
Hi all. I'll try to make this short. I have been hauling wood pellets by the ton for several years now with various 1/2 ton pickups. Never had a problem and didn't even think about it. Last week I went to h d and bought a ton. The guy came out with the load and looked at the truck, looked at me, then looked at the truck again. He asked if I ever had a ton on the truck before. (First time I was ever asked that). I said no it's new, but I did have a 04 150 screw that I loaded up. He loaded it. It seemed to sag a little more than my previous truck. I drove home, approx 4 miles without any problems. Then I got to thinking about the look he gave me and the fact that the truck sat lower when loaded. I went online and found people talking about having broken springs, blown tires, etc after hauling pallets with Half ton pickups. Anyone here haul pallets with their 150s? Any problems? I don't want to screw up a new truck. The ford site said my configuration had a payload of 1888 pounds. The door sticker says 1700 pounds. Am ok just going 4 miles with it? Thanks in advance.
Hi Steve,
The problem isn't so much the max payload of the truck but the axle ratings. Looking at the spec sheet your empty rear axle weight should be right around 2,300 lbs. The rear wheels themselves are only rated for 2,025 lbs each, which means that you are over your rated capacity of the wheels with a ton of pellets in the bed. Your RAWR on your sticker is probably 3,850, so you would be a good ~500 lbs over your springs rated capacity.
That being said I've run overloaded without incident, and I wouldn't think twice about hauling a ton of pellets for only four miles. My dad's 2010 F150 has done exactly that a couple of times without incident. To minimize the weight on the rear axle I would make the haul with 1/4 tank of gas and place as many bags as possible on the floor of the front seat and the back of the cab. This will place weight on the front axle and keep the overweight-ness to a minimum on the rear axle.
I just did the pellet run over the weekend, and I had the snot nose punk refuse to load the truck till I got LT tires? So I had to load them buy hand boy was I pissed off! I will never buy them from OSH again! it did good and the kid could of had a good thought with the LT tires but the truck did good!
My sister just had HD drop off 5 tons of pellets at her house, she'll be good for this winter and most of next.
Of course you'd be over GAWR, but the tires were not the limiting factor here.
I don't think so, they were wrong plain and simple. The factory tires are rated for 2,644 lbs per tire at max PSI. Which means that your tires can handle a whopping 5,288 lbs on the rear axle if properly inflated. Which means they can handle far more than the max payload of the truck and easily handle a ton of pellets.
