Wiring harness?
Wiring harness?
Hey all. Im redoing my 59 f100 as a frame off resto mod. Id like to do all new wiring. Was thinking about going with a kit from painless wiring. Anyone used them or what did you go with? I got rid of most of the old rat chewed wiring.
My truck will have a 445 (390 fe stroker), and autometer gauges to start. Not sure what to look for in a new wiring harness here.
Thanks
Thanks
Fuse Block Wiring
The corners broke off of my 87 5.0L fuse block and I would like to know how the wires are attached to the fuse block?
I have an opportunity to purchase a fuse block including the complete wiring harness but I do not want to "get over my head". A picture from the seller shows that all of the separate "looms" have plugs on the end. Is the harness a "plug and play" installation? My truck is a XLT Lariat with full power and the donor is a basic vehicle without the same options.
Thank you!
Boon
1957-1966 Ford Pick-Up S or L WB-Ron Francis Wiring
Or generic kits(what I used) just tell them what engine,alt etc you are using and they can build a kit for you.
XP-67 Ford Powered EXPRESS Wiring System-Ron Francis Wiring
Comes with every thing plus headlight switch.They make a kit for our trucks
I also used the EZ wire kit. IT wasn't too bad but there were a few things I had to fix such as the fuel pump wire being hot all the time, gauges/idiot light is powered in acessory mode, the main wire from battery to fuse box isn't quite heavy enough.
For the money it's a good deal but just know you might have to do alittle engineering/tinkering to get it perfect.
I was looking at the Painless kit but just didn't have the money for it then.
1960 F100 Wiring
All,
I used the 20 Circuit kit from Speedway Motors. The price is very reasonable and the kit was super-easy to install - my first for a complete wiring harness.
In retrospect, I could have gone with the 12 Circuit kit and saved more money. Oh well.
I added the headlight relay kit and aftermarket gauge wiring kit also. works great.
Nick in WI
Nick in WI
All,
Nick in WI
Nick in WI
tjewitt21
03-28-2014 11:50 AM
