Turbo a 360?
Throw the crank, rods and pistons in the junk pile. Upgrade to at least a 390 crank and rods, with pistons that make enough compression to work with your hot cam. You can go out to 445 with that engine.
Survival FE Engine Kits
Your pistons would actually get you 9 to 9.5 compression on the 390 crank and rod, but my bet is they are worn out, which is why I say toss 'em. Even if they are in spec, the ring lands have over 40 years of hammering, so why chance them in a new rebuild.
As for the turbo, you won't need it, and even though the 360 would seem to like a turbo, being that it is a low compression engine, the sunken piston and lack of quench would seem to me to invite detonation and make for trouble.
1971f100restoration
25
01-12-2017 02:00 PM
turbo2383
21
12-04-2007 08:10 PM
biggut
12-31-2004 09:09 PM
54effie
16
11-07-2004 07:38 PM
barbster
07-05-2002 04:46 PM
