thanks! I will pass this along- the tech is a good guy-friend but HATES me telling him what it is and how to go about it----- I call him mr personality.....
if it isn't warrenty it will just limp to his house its closer.
so here is the real question that has been irking me since this happened....
is now the time I delete the dpf and such? I have been warned that this may not be cheap to fix so........ truck has 110k on it and is out of warenty and only has a little of the esp warenty left........
Tuning is not cheap either, it isn't legal, your truck will run much better, you MPG will increase a little. Lot's of pro's and cons, spend a little time reading and decide what way you want to go. The EGR valve replacement isn't a big deal, here's one from Ebay, new, $195.00.
http://www.ebay.com/itm/2008-2010-Ford-F250-350-450-550-6-4L-Diesel-OEM-EGR-Valve-CX-2366-8C3Z-9D475-D-/331061545210?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d14ce48fa&vxp=mtr
thanks. the tech (friend) is blowing this out of proportion then and freaking me out----
hell I thought of putting out real money to delete and all.....
truck has been parked for a week- went to take to the mech for repairs and it started but wouldn't idle or rev so it wouldn't make it- turned around into loading onto a trailer and hauling it out and then it wouldn't start.... dead dead batteries-- loaded and delivered though....
here is the report to date-
egr valve and housing replaced
batteries tested to be very weak
alternator very corroded
new belts and tensioners
still looking over truck
advised to replace batteries and alternator- havnt decided fully yet
I'd advise you to read your ESP contract carefully. I do not see EGR anything listed as excluded under any of the ESP levels. Alternator is listed as covered under all ESP levels as well.
truck is an late 07 (08) with 110k on it so it is out of regular warrenty. the esp is the only one left. I was told the egr is emmisions related and falls under that and not under the powertrain esp- even though it is in the motor....
I will search for the contract though....... thanks
