Engine Noise - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Engine Noise
Old 11-28-2013, 03:30 PM
HALO1 HALO1 is offline
HALO1 is starting off with a positive reputation.
Engine Noise
Has anyone had trouble with engine noise on start up of a morning? My 2013 6.2 F250 makes what sounds like a lifter picking sound on cold mornings. After it gets hot it goes away no sound. It started doing it about a week ago before the oil change (used Motor-craft oil and filter 5w-20). It gets noisier with the more throttle you give as you go down the road cold and when you stop at a red light you can hear it. 10500 miles on the truck.
Thanks
Old 11-28-2013, 03:43 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
We ( my shop ) had one with the same complaint . The lube guy put in the wrong oil by accident . We had just switched tanks , he did not read the tank before pumping oil out . The tanks were not in the same order as before .
Old 11-28-2013, 04:48 PM
I thought that but it was doing it before the oil change and still doing after.JWC 3 where are you located at in TN?
Old 11-28-2013, 05:40 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
That should probably go back to the dealer. Some of us have a tick/knock/noise briefly at startup but have been told by dealers it's ok. My noise goes away after a second or so.
I do have ANOTHER noise, knocking at 2500+ rpm under slight acceleration. Need to get it into the dealer, factory warranty is up in 3 weeks...
Old 11-28-2013, 06:25 PM
Well I guess I will be calling the dealer in the morning.
Thanks
Old 11-28-2013, 11:03 PM
JWC 3's Avatar
Quote:
Half way between Nashville and Chattanooga . Manchester TN .
Old 11-29-2013, 06:52 AM
I know where it's at, I live in Harriman
Old 11-29-2013, 09:46 AM
Slowpoke Slim's Avatar
Slowpoke Slim Slowpoke Slim is offline
Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.
I get a slight ticking noise when it's cold that goes away quickly.
But, I get a loud "whirring" noise coming from the fan/front of engine when I start up on a cold morning. It has to be down to +15 to +20 degrees or colder to hear it. But the whirring continues until the truck warms up. I admit it's kind of annoying to listen to.
Restarting it once it's warmed up, and you don't hear it at all.
It's done it since day one.
Old 11-29-2013, 12:44 PM
Slowpoke - Most likely the fan. I have the same thing. It hasn't been 100% confirmed, but it may be similar to what's in the thread below:
http://www.ford-trucks.com/forums/11...ld-starts.html
Old 11-29-2013, 06:25 PM
Dave HM Dave HM is offline
Dave HM is starting off with a positive reputation.
my 12 is the same way slow poke
Old 11-30-2013, 07:59 AM
JohnnyThunder JohnnyThunder is offline
JohnnyThunder is starting off with a positive reputation.
Quote:
So is my 11
Old 11-30-2013, 09:26 AM
Thanks for the replies. I think I'd mentioned it once when I first got my new truck, but don't remember the reply.
I didn't think it was anything serious, as it's never gotten any worse, and it hasn't come up during dealer service.
It is annoying however, and a bit embarrassing when I start it up to leave work at the end of the day. People tend to stop and look/stare at it. I can't blame them for thinking something must be wrong with it.
Old 11-30-2013, 07:39 PM
You got it all wrong. They think you have a helicopter in disguise and are gawking and wondering if you are gonna pull pitch or not.
Old 12-05-2013, 07:22 PM
Well I got the truck in the shop on Monday and they called today and said the noise I was hearing was the injectors. I spoke with the tech that was working on it and he said he drove it hot and cold for 15 miles or so and done different test and that is what they have come up with. I then asked the service manger to have a different tech look at it tomorrow and see what they come up with. Has any else heard of this?
Old 12-08-2013, 08:13 PM
The injectors are noisy on these trucks, I had mine back immediately after I drove it off the lot and was told the same thing, just noisy injectors. I didn't believe them so I got a mechanics stethoscope out and sure enough, that's where the ticking came from.
Just dropped mine off at the dealer tonight to get the knocking looked at (along with a few other small ticket items). Worst of it was going back to stock (tuned). These trucks are so limited with the stock tune!!
cold start lifter noise?? jimzpsd 2017 Super Duty 9 02-12-2017 07:04 PM
Can synthetic oil cause an engine to make more noise? 640 CI Aluminum FORD 2009 - 2014 F150 23 01-28-2017 09:44 AM
2015 F350 Platinum 6.2L ticking noise on startup F350FordToy 6.2L V8 61 12-21-2016 07:16 PM
Metal in Oil, Oil in coolant, loud rattle on accerl 99 expedition and idle persistan hikerpunk Modular V8 (4.6L, 5.4L) 1 03-20-2006 06:08 PM
V10 piston slap 10strokin Modular V10 (6.8l) 15 10-27-2005 08:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
