I've got the Air Lift wireless air control system for my truck and want to add a tank to the system. What do you guys have for tanks and how do you have them mounted? Where did you mount a chuck for an air hose for tires? How big of a tank should I go with?
I've been looking into this because I want to be able to run air tools and air down and up at leisure so I've been looking into how they work. The viair 2 gallon tank can be u bolted to the frame under the passengers rear door. There's a few threads on here. I'm looking at a thin 5 gallon tank as in also looking to run Nathan air chimes
You can probably put two small tanks between the frame rails between the X bracket and the bed (if you lifted the bed for the install). Nice and clean, and protected.
Fellow FTE member EpicCowlick did a Train Horn set up with Onboard air to do tire inflation as well on his 2011 F350 Superduty 6.7. He even made a little video as he did it.
Have a look and see, maybe it will give you some ideas for mounting and what not. Hope this helps.
