inline trans filter only - skip dropping the pan?
Doggone it, may need to go there. Just got the coolant filter from them. Is this how it's going to be? Going from fluid to fluid, filtering this and that. Already got oil, fuel and coolant covered, now tranny needs spin-on, then there's power steering, transfer case, rear diff, front diff...I'm starting to foam at the mouth... might need to filter that!
But that's not really a bad thing..........
Pop
Here is an excellent write-up on the conversion:
https://b7445ba3-a-62cb3a1a-s-sites....attredirects=1
Thanks again for your write up on the spin on filter set up. The only thing I am going to do different is use a Fram HP1 it has a built in 23psi bypass valve built in. I really like how you made the plate and mounted it up by the bumper. Nice and out of the way of anything poking a hole in the filter.
on
Jeff if you thinking of going with a spin on filter set up Pop did his own and I like where he installed his over the kit Dieselsite kit mounts it. Pop has a link in his signature with the write up. I used it to get the parts together for mine. The little magnets are great !!
#28
#30
