Thanks, got P0272 code cylinder 4 injector circuit /balance. Diesel shop in South Africa wanted to know to see if they can work on it...seems quite hard to import reman injectors to Africa, most want core charge etc.
rgds
willem
Cheers!! Thanks. I never planned to use the internet as much, but you guys are very helpful. Lonely world out hee in Africa for US products....but not Cessna, very well presented!
I checked the FICM voltage and they seem fine as per specs published here...how do you clean the spool valves? The vehicle struggles to start when cold and has a constant jerk until about 2200rpm then runs ok. just completed 2600km trek to SA coast, but worried....
clened EGR valve 1500km back was slightly open with carbon. The MPG seems good but def not running well.
