Project Highboy work truck - Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
Old 11-27-2013, 07:26 PM
iggybob44's Avatar
iggybob44 iggybob44 is offline
iggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant future
Well, my 76 is an excellent starting point for a building materials/firewood/dump run truck......My daily driver Dodge Diesel has a shortbed and a camper shell, so the 76 Highboy seems like a good vehicle for this usage. its got integral power steering, front disk brakes, and a huge PTO winch on the front. Im thinking about adding some overloads to the rear, a lumber rack and headache rack, and building a front mounted detachable A-frame with a sheave to allow me to redirect the winch pull for pulling sections of trees up hillsides for firewood. I see tons of available wood on roads that dont have a wide enough pull off to allow me to run the truck for an easy straight pull. What im envisioning would look like an oversized tow bar that would plug into the huge winch front bumper, have a sheave on the end to allow up to a 90 degree sideways winch pull. Ive already figured that if i build it with a provision for driving a couple t-posts or construction stakes into the ground towards the front of the A-frame to secure it from pulling the vehicle sideways, and if i limit the the logs pulled to relatively small size i shouldnt have any problem. Im also planning on adding a 2 gauge welding cable/polarized plug power lead to the back of the truck, so i can attach a winch with a receiver mount to my back bumper easily.
Front replacement bumper...starting to look at options jonrjen 6.7L Power Stroke Diesel 19 02-24-2015 12:07 PM
Recovery winch - Theory and Ideas - Round 2 KC8QVO Offroad & 4x4 8 10-27-2014 07:30 PM
Winch Me Map Man 1 6.7L Power Stroke Diesel 7 07-16-2014 10:12 AM
PTO Winch questions iggybob44 Offroad & 4x4 12 08-01-2013 11:19 PM
71 highboy pto winch Grunt85 1967 - 1972 F-100 & Larger F-Series Trucks 3 07-25-2013 10:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
