e4od torque converter problem? - Ford Truck Enthusiasts Forums
Old 11-27-2013, 02:04 PM
larocksg larocksg is offline
larocksg is starting off with a positive reputation.
hello, i recently bought a 95 f250 psd with a e40d. im not exactly a expert when it comes to transmissions, but it has 240000 miles and it seems like the trans is starting to go. what it does is in every gear except o/d it seems like it slips and then around 45-55 mph it will lockup hard (drop about 300-600 rpm). there is also a scraping/loud whirring noise like there's a bad bearing around the tc/flex plate on the trans. the noise gets progressively louder as the trans warms up with no noise at startup and lots at operating temperature. it makes the noise in every gear including park and neutral until the tc locks up in o/d. when in o/d with no noise if i let my foot off the gas going about 60 mph the rpms drop to a idle and the noise comes back. after about 5 seconds if i reapply gas the rpms go up to about 2000 then drop down to around 1500 with a jerk and the noise stops. during normal driving it shifts a little late and sometimes very hard. also under full throttle the noise stops after 1st gear and only comes back during shifts. when i changed the fluid there was only about 2 quarts and it smelled burnt. i topped it off and nothing changed. i also did a slip test and it only revs to 2000 rpm. when i first got the truck the o/d light was flashing but that went away in about a day of driving. im just wondering if my whole trans is toast or the converter just needs to be replaced or something else. any input is appreciated.
E4OD Overdrive not working? Kanglar 1987 - 1996 F150 & Larger F-Series Trucks 10 02-01-2017 11:05 PM
Transmission Troubles.... KJNDIVER 1999 - 2003 7.3L Power Stroke Diesel 42 11-24-2016 02:08 AM
Sudden TC failure?? RGTFanatic 1997-2006 Expedition & Navigator 3 04-17-2013 01:32 AM
2005 Escape Trans Problems, Looking for Advice sirvictory Escape & Escape Hybrid 0 12-09-2012 12:54 AM
'01 Expedition, torque converter or other tranny problem? lincolnboy73 1997-2006 Expedition & Navigator 13 08-17-2012 04:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
