ECT Temps while its cold
Old 11-27-2013, 01:23 PM
rowekmr's Avatar
rowekmr
rowekmr is offline
Hello
This is my first winter with my 6.0L and with the recent EGR delete notice the warm up time is longer and if I start driving it takes a while for the ECT to get into the 180F's which is when the heat starts to blow hot. The most I get is 188F on the highway and it takes more than 15minutes to get there. I assume this is normal but am wondering does anyone put cardboard or anything in front of their radiators like the big rigs to keep more heat in the engine?
Old 11-27-2013, 01:43 PM
loubell's Avatar
loubell
loubell is offline
thermostat replaced?
Old 11-27-2013, 03:06 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
It's a diesel not a gas motor. It takes a bit to heat up.
As for ECT if it's well under 32 and you're seeing 188 on the temp on the highway that isn't too bad.
Josh
Old 11-27-2013, 03:37 PM
rowekmr's Avatar
rowekmr
rowekmr is offline
I'll have to check but I am sure the thermostat was replaced when I had all the work done. I looked and see others with the OEM thermostat having similar temps so I guess this is normal. I am looking at now partially blocking radiator to retain more heat. Some use cardboard and I saw some with cowl blankets.
Old 11-27-2013, 07:35 PM
VQT's Avatar
VQT
VQT is offline
There are people over the Excursion forum either made or bought stuff to put in front of the radiator to keep the engine warmer in the winter. I think one did use cardboard, so yes it doable.
Loopy
1999 to 2016 Super Duty
11-13-2011 11:03 AM
cam_12484
2004 - 2008 F150
12-08-2009 07:46 PM
enf303
12-14-2008 02:53 PM
RyanJake
02-15-2006 07:09 PM
tombob
1978 - 1996 Big Bronco
12-02-2002 12:14 PM
Quick Reply: ECT Temps while its cold
