Afternoon to you Rick...... mid 40's and sunny here. When I was out at lunch time, I stopped at the gas station to put some air in the tires on the truck along with rinsing the salt off of it. It was decent enough I did not wear a coat.
Afternoon Phil, Neil, Rick. Like Phil said, it's frickin' cold out. And will only get worse the next few days. So, that means I get to deal with a cold, grumpy diesel after work!
Afternoon Neil and Pat!
Was out this morning and didn't need a coat either but that is due to change tonight.
I've never had a problem getting Black started. She's just an irritated bitch until she's warmed up! I still have the hot tune in her also, so she's a little bit touchy on the throttle until she's warmed up.
So you are both cold and grumpy... the perfect pair!
