Tonneau cover while towing fifth wheel - Ford Truck Enthusiasts Forums
All Other Items for Sale All other items (non Ford Truck related) for sale. Tools for the garage, brake pads for your 66 Mustang and your beer fridge go here.
Old 11-26-2013, 04:33 PM
mrpd114 mrpd114 is offline
mrpd114 is starting off with a positive reputation.
I have a 2011 F-250 diesel and a 36' fifth wheel. I would like to somehow cover my truck bed as much as possible while towing with a soft cover to protect items in the truck bed. This would require an access hole for the hitch.
Any thoughts?
Old 12-02-2013, 11:25 AM
El Camino Man El Camino Man is offline
El Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to behold
I think your in the wrong spot lol. Maybe a mod will correct this?
Back to the question! Iv seen a truck with a 5er and a Reese Sidewinder hitch. This basically moves the pivot point of the trailer from the hitch to the pin box. Its actually for short bed trucks but I don't see a reason a long bed truck couldn't use it. The truck Iv seen it on had a hard cover and he simply cut out a hole the size of the pin box. Since the trailer now pivots at the top of the pin box and not the hitch, 90% of the bed is still covered by the tonneau cover. I hope this makes sense lol. Maybe I can get a pic.
If you don't want to spend the money on another pin box, then I don't see why you couldn't modify a soft cover to fit the front half of your bed. Of course, if it rains, the water will slosh forward and get the bottom of whatevers in the bed wet. Some ingenuity could possibly fix this? But the same is true for the above mentioned idea as water can get in the hole where the pin box is... Some experimenting ought to yield you the results you want!
Old 12-02-2013, 11:31 AM
Here ya go!
The camper now pivots at the top of the pin box, so he can have a very small hole in his tonneau
Old 12-08-2013, 08:01 PM
That looks close to what I was thinking of. Maybe if the open sections could be zippered somehow to tighten the open spaces only limited rain water would enter. Thanks
Fifth wheel bed mount hole cover / pucks CA-F250 6.7L Power Stroke Diesel 20 11-11-2016 02:07 AM
bed cover for fifth wheel johndeerefarmer Fifth Wheel & Gooseneck RV Towing 17 09-18-2016 10:48 PM
5th wheel friendly tonneau covers. Lees350 Fifth Wheel & Gooseneck RV Towing 12 10-25-2015 10:12 AM
Towing Capacity - Fifth Wheel, 2001 F350 Crew Cab Lariat DavidCarr 1999 to 2016 Super Duty 2 02-21-2015 05:32 PM
2008 F-250 fifth wheel hitch weight bgathey Fifth Wheel & Gooseneck RV Towing 5 10-06-2011 02:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
