wiring diagram for 1985 Ford F150 - Ford Truck Enthusiasts Forums
Old 06-23-2003, 02:41 PM
madmom madmom is offline
madmom is starting off with a positive reputation.
Question wiring diagram for 1985 Ford F150
does anyone have the wiring diagram for Ford F150 pickup 1985? If anyone has it please email as soon as possible. I would really appreciate it.
Old 06-23-2003, 05:52 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
If you want very nice factory diagrams go to www.helminc.com and see if they are still in stock.
If you want fairly decent diagrams, go to the local auto store and buy one of the Haynes manuals for your year truck. I have an older version and it has pretty good diagrams.
If you want a poor representation of some general circuits, but it is free, then go to autozone.com and click on repair info
Old 08-06-2013, 02:22 PM
DaVultch DaVultch is offline
DaVultch is starting off with a positive reputation.
1985 wiring
I've been on this thing for over 2 hours now, tring to find a wiring diagram to a 1985 6 cylinder F150
I knew I could go by a $30 Manual, Aa Duu, No one Knows of a Site that has free Downloads for this.... Watta waste of Time
Old 08-06-2013, 02:25 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Yep... we're not into copyright infringement here... best thing to do is go purchase the factory wiring diagrams from a place that sells used automotive literature.
Old 08-06-2013, 08:59 PM
Franklin2's Avatar
Old 08-06-2013, 10:36 PM
Stangrcr1's Avatar
Stangrcr1 Stangrcr1 is offline
Stangrcr1 has a good reputation on FTE.Stangrcr1 has a good reputation on FTE.
I bought the factory manuals off Ebay for my 82. Best money spent on the truck so far, and all of $40 including shipping.
If you have a wiring issue, how about an explanation. Maybe we can help.
Old 08-07-2013, 03:45 PM
Wiring
Hey Thnx,
I picked up a 85 F150 Xcab, with a 5.8 HO.
Just found out this truck came with a 300 6 cylinder
so the color codes arn't matchin up.
For instance a Yellow fuse link wire fron the solinois Pos. side is Burnt out where did that Go? I have NO Horn How's that get wired, Ect. Ect.
Old 08-07-2013, 05:21 PM
Franklin2's Avatar
Different engines won't affect much on the colors and functions of most of the wiring for the chassis/body. That wire you are talking about over at the solenoid + is the same no matter what engine. That's the main power wire and is shown in this diagram.
http://repairguide.autozone.com/znet...3f80212308.gif
In the middle of the diagram there is a wire that says "To starter relay" and is a yellow wire that leads to the ignition switch.
The same diagram has a wire leading from the steering column area that says "To horn switch". I know it's not much. If I were you I would get a haynes from the store and see if they still have the diagrams in the back of them for these trucks. They are usually pretty good and onyl around $19 or so, and you get a lot of other info on the driveline and the body.
Do you have cruise or not? If you have cruise, you have a horn relay, and the button on the steering wheel grounds the wire to make it activate the relay and send power to the horn. If you do not have cruise, then the horn button is a simple switch that sends power directly to the horn with no relay. The first thing I would do is find the horn, and put power to it to see if it works.
Old 08-07-2013, 07:50 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
http://www.ebay.com/itm/1985-Ford-F150-F250-F350-Wiring-Diagram-85-Pickup-Truck-Electrical-Schematic-/400268506968?pt=Motors_Manuals_Literature&hash=item5d31dcb758&vxp=mtr
That's what I got.
Old 08-07-2013, 09:52 PM
Stangrcr1's Avatar
Or this. it will show you every wire, connector, switch, relay, etc.
http://www.ebay.com/itm/1985-Ford-Bronco-F-250-F-150-F-350-Wiring-Diagrams-Electrical-Manual-EVTM-/310716923686?pt=Motors_Manuals_Literature&hash=item48582bff26&vxp=mtr
Old 10-02-2016, 07:42 AM
dieterschmied dieterschmied is offline
dieterschmied is starting off with a positive reputation.
what does copyright infringment have to do with his problem?
Most of us are here to help.
Does anyone have a 1985 EVTM? reamer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 24 06-05-2016 01:41 PM
1985 f150 fuel pump relay question captain1997 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 03-08-2016 08:11 PM
Headlight wiring diagram Eddillard79 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 07-31-2015 11:23 AM
2014 Ford F150 Limited Wiring Diagrams george6488 2009 - 2014 F150 0 04-28-2014 08:48 PM
1985 F 250 Diesel 4X4 Wiring diagram 9670int 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 01-15-2009 11:12 AM
Tags
1985, 1986, 85, 86, cyl, diagram, engine, f100, f150, ford, fuse, pickup, stereo, truck, wireing, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
