tow package..?
tow package..?
hey guys, I have heard some talk about tow packages.. and was wondering how I could find out if my new (to me) expy has the package. its a 97 4.6 xlt with the tow hitch welded onto under the rear bumper. (looks stock) thanks for any help. I'll be towing my wave runner and a 24' boat about 1 mile.. I should be fine right?
-john
-john
tow package..?
My '97 with factory tow package came with:
- Class III rated 2" square receiver tube mounted on a curving
square tube of the same size that bolts onto the frame
- 7 pin wiring harness with receptacle/cover mounted on bumper
- 130 amp high output alternator
- transmission cooler
- engine oil cooler (on 5.4L only)
- 3.73 differential ratio
- 78 amp hr. battery
- rear load leveling suspension (4x2 only)
Regardless of equipment don't exceed when fully loaded, the maximum GCRWR.
The LSD and 4 corner air I have were optional extras.
tow package..?
I have a 98 XLT and just had my hitch bolts upgraded from a 2000 recall for insufficent hitch bolts. I'm no mechanic but after looking at the before and after the new bolts are much larger. My hitch is bolted on also not welded. After reading this forum and sufing around the net there has actually been hitch's that have come undone or extremely loose while towing. I would look into the recall!
tow package..?
Probably bolted and not welded. Also, see if you can tell on the hitch if it's a Class I, II, or III design - that will dictate what your hitch is designed to handle. Also, tow package means transmission cooler - look around the radiator for an additional cooling unit and follow the lines to see if they go to the tranny. If you are towing - DON'T use overdrive
tow package..?
Along the same line of question as the original post, I am wondering if there is some information on the door plate sticker that positively identifies the vehicle as having the "tow package". I am in the market for a used Expedition and it is my impression that the seller will claim that the vehicle has a "tow package" simply by the existence of a hitch. I see that tsdrallyer knows exactly what his tow package includes but some of those features are difficult to see if you are simply looking at the vehicle. One thing I tried to confirm was the additional/upgraded trans cooler. It appears to me that there is a small air cooler visible throught the grill but that could be on every Expedition as far a I know. The only item I have been able to confirm is the rear end specs which are coded on the door plate sticker.
Any help?
BTW, IMHO, I do not think that a factory hitch would be welded to the frame. Also, I would be surprised to find that the Expedition tow package would be offered with the 4.6.
Dan
Any help?
Dan
tow package..?
Dan [/B]
Dan [/B]
BigMick
15
12-08-2010 03:29 PM
impwrdbym
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-22-2008 06:11 AM
97expy5_4
1997-2006 Expedition & Navigator
06-11-2001 02:58 PM
