E-Fuel Mod and Bigger Rear Tank - Page 3 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #31
Old 12-05-2013, 08:08 PM
DarkStarMedia DarkStarMedia is offline
DarkStarMedia is gaining momentum as a positive member of FTE.DarkStarMedia is gaining momentum as a positive member of FTE.
Wow.. that looks low... what is the capacity difference?
Richard
  #32
Old 12-05-2013, 09:55 PM
lindstromjd's Avatar
lindstromjd lindstromjd is offline
lindstromjd is starting off with a positive reputation.
Quote:
Richard
To be honest, I can't afford to fill it all the way up right now. So I don't know exactly how many gallons it holds. But as far as I know, it's a 38 gallon tank. And it works perfectly, all the way down to 1/16 of a tank, which is the lowest I've let it get down.
And the tank really doesn't sit as low as it looks. It's just above even with the rear differential. And if I ever get around to doing my 4x4 swap, then there wouldn't be any height problems at all.
Efuel fail... selector valve fail...selector switch maybe failed..WTF nossliw 1994.5 - 1997 7.3L Power Stroke Diesel 21 08-15-2016 04:08 PM
1994 Ford F250-Looking for a larger rear mounted fuel tank Ex-ChevyOwner Fuel Injection, Carburetion & Fuel System 2 10-18-2015 04:42 PM
Custom fuel pump/selector DrZoom 1987 - 1996 F150 & Larger F-Series Trucks 1 05-18-2015 04:27 PM
Edit: Electric fuel causing more mods? Awitte58 1994.5 - 1997 7.3L Power Stroke Diesel 34 05-18-2013 07:11 PM
dual fuel tank selector valve jhm 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 07-30-2003 03:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
