E-Fuel Mod and Bigger Rear Tank - Page 2 - Ford Truck Enthusiasts Forums
Old 11-28-2013, 01:08 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Quote:
Originally Posted by rodneywar View Post
Glen I think he is gonna use a **** tank!!
, got it!!
Old 11-28-2013, 04:46 PM
dougbrown's Avatar
dougbrown dougbrown is offline
dougbrown has a very good reputation on FTE.dougbrown has a very good reputation on FTE.dougbrown has a very good reputation on FTE.
Dam auto correct!!!! Excursion tank.
Old 11-28-2013, 06:20 PM
Pretty funny!!
Old 11-28-2013, 09:03 PM
Brettboat Brettboat is offline
Brettboat is gaining momentum as a positive member of FTE.Brettboat is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by madpogue View Post
If it's a 4x4 truck, there are no "straps". The skid plates hold up the tank.
Wrong... Mine has straps and a skid plate right under it... 97 250 ccsb 4x4
Old 11-28-2013, 09:28 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Quote:
......You gotta admit Doug, that was pretty funny! But back to the tank.....how much modification is required to use an Excursion tank?
Old 11-29-2013, 12:35 AM
matts156's Avatar
matts156 matts156 is offline
matts156 is starting off with a positive reputation.
I'm not familiar with the e-fuel conversion. What's it all about? Is there a good thread on it?
Old 11-29-2013, 08:10 AM
dougbrown's Avatar
You will need to get, tank, straps and skid plate. Then u may need to make a new cross member for the rear tank straps. I have only helped put one in a sd truck. Wasn't that hard with the bed off and knowing how to fab steel helps.
Old 11-29-2013, 09:18 AM
Quote:
http://www.ford-trucks.com/forums/94...el-system.html
Performance Injectors for 7.3L Ford Power Strokes
Electric Fuel Conversion - PowerStrokeNation
Electric fuel system conversion - PowerStrokeNation
Old 11-30-2013, 01:12 PM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Quote:
Your REAR tank has a single skid plate?
Old 12-01-2013, 10:30 AM
Awitte58's Avatar
Awitte58 Awitte58 is offline
Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.
Are you referring to those black rubber strips on the skid plate pieces as 'straps'?
Old 12-02-2013, 10:36 PM
^^^^^ More to the point, can you remove the skid plates without the tank falling off the truck?
Old 12-03-2013, 12:38 AM
JCart JCart is offline
JCart is starting off with a positive reputation.
My F26D (get the F26E) came with longer bolts and spacer tubes for each bolt. Mine did not have straps on the bottom side of the tank but does on the top side. Yes basically it will fall off the truck when I undid the skid plate. I used single hand operation bar clamps to aid in holding up/ lowering the skid plates and tank as I did this by myself.
My spare fits under there no problem and I have not touched with it yet, mind you my red sig truck is a bit higher then a stock truck by guessing 4"? I did notice with the 38 gallon tank, 600lbs ATV and 50 gallon auxiliary plus stock front, it did squat down too much for me. I then installed firestone air bags and this works wicked.
jrc
  #28
Old 12-03-2013, 12:28 PM
DZL JIM's Avatar
DZL JIM DZL JIM is offline
PREMIUM SPONSOR
DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.
I've never seen a truck with both straps and skid plate.
Unless you mean straps on top and skid plate under, which they all have.
With the 38 gallon tank, we cut pieces of small dia. gas pipe and used longer bolts to drop the skid plate down (which holds up the tank), then used more pieces of pipe to extend the spare tire hangers. Looks totally stock.
__________________
'96 F-350 Reg Cab 4x4 PSD
'05 F-250 6.0 cc 4x4
DZLJIM.com
  #29
Old 12-05-2013, 05:44 PM
GondolaRides GondolaRides is offline
GondolaRides is starting off with a positive reputation.
Quote:
Originally Posted by lindstromjd View Post
If it's worth looking into for you, the front tank can be modified to a bigger tank, too. I have a Super Duty tank on mine, which almost doubles the capacity, and the sending unit wires right in to the truck. It hangs down kind of low, but no lower than the rear axle.
what tank did you replace your front tank with?
  #30
Old 12-05-2013, 06:34 PM
lindstromjd's Avatar
lindstromjd lindstromjd is offline
lindstromjd is starting off with a positive reputation.
Quote:
How to: Mount a Super Duty front fuel tank to an OBS - PowerStrokeNation : Ford Powerstroke Diesel Forum
This.
Efuel fail... selector valve fail...selector switch maybe failed..WTF nossliw 1994.5 - 1997 7.3L Power Stroke Diesel 21 08-15-2016 04:08 PM
Custom fuel pump/selector DrZoom 1987 - 1996 F150 & Larger F-Series Trucks 1 05-18-2015 04:27 PM
E-fuel issues Fogline farmer 1994.5 - 1997 7.3L Power Stroke Diesel 11 09-25-2013 05:42 AM
38 Gallon Rear Tank and E-fuel Awitte58 1994.5 - 1997 7.3L Power Stroke Diesel 119 07-04-2013 12:30 AM
Edit: Electric fuel causing more mods? Awitte58 1994.5 - 1997 7.3L Power Stroke Diesel 34 05-18-2013 07:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
