351 Specs?
351 Specs?
High guys, I just picked up a 351 EFI engine and zf 5 speed for 225 bucks. It will probably be going into my jeep cj that I am just starting to work on. Can you guys give me the specs on these engines, and what it takes to convert them over to mass air. Also, when did they start getting roller cams? Any info on these motors would be great. I know alot about the 5.0 mustang motors, but not the 5.8's.
For power, I believe at their peak they made 210hp and 325lb-ft of torque. MAF is not for the faint of heart. You can either get all the MAF intake setup and meter from a truck as well as the wiring harness and appropriate EEC and swap the whole engine bay harness, or r you can get all the MAF intake parts including meter, an overlay injector and MAF meter harness and an appropriate EEC. The overlay harness requires repinning of the EEC connector. For the EEC you can use the popular manual trans Mustang EEC's since you are running a ZF5.
I guess I should have clarified a little more. I am after the specs as far as what year roller cams came out, what the pistons are made of, cranks, rods, different HP years, etc. I know about the rest of the mass air and parts interchangeability of the 5.0/5.8. I plan on running a 89-93 mustang harness and pcm.
I am not sure of the year, it is out of the truck. I know it is a EFI but that's about it so far.
thanks guys
thanks guys
Some good info in here: Engine_Specifications
It's not the end all bible of Ford engine specifications but it is a good reference.
Tmarsh1022
06-24-2016 01:26 PM
f1001969mike
18
09-28-2012 09:36 PM
bob1987f
04-29-2009 10:34 PM
