1995 5.8 valve setting issue - Ford Truck Enthusiasts Forums
Old 11-25-2013, 10:13 PM
tempaz tempaz is offline
tempaz is starting off with a positive reputation.
Exclamation 1995 5.8 valve setting issue
I'll try and be brief and to the point as possible. 1995 Ford F250, 5.8w motor. I acquired a bad miss and found I had 0 compression on the left front cylinder. After I pulled the head I found a chipped valve and replaced it. I pulled the other head off to replace the gasket while I was in there. I put the heads back on, torqued the rockers to 18 foot pounds, immediately after did a compression test to see if I had any compression problems with my job. Only to find that a few of the cylinders had 100-115 pounds compression while others had 150. I loosened off the rockers and found that those weak cylinders jumped to 150 psi. SO obviously the valves are set too tight, however, I don't know why. My only theory is, that the lifters are not giving at all. I started to check them by disassembling them and found that they were sticking/seized. Could that be my problem with the valves being set too tight, or are they supposed to be almost impossible to collapse when they are charged? I put a hell of a lot of force on a couple to try and get them to collapse while charged and they didn't budge. HELP?
Old 11-26-2013, 05:23 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
Rockers should be torqued to 25 ft/lbs. If the lifter plungers are fully compressed with the rockers torqued, then your pushrods are too long. Are the rocker fulcrum channels in place under the pedestals ? Have the heads been milled ? What head gaskets did you use ? Now if the lifter plungers are sticking or seized, they should be replaced, if there's that much gunk inside them I'd hate to think as to what the bearings in the bottomend look like.
95 valve adjustment issue markfuga Ford Inline Six, 200, 250, 4.9L / 300 16 03-04-2016 08:51 AM
Finally think I figured out '68 F100 backfire mnkeeking 1967 - 1972 F-100 & Larger F-Series Trucks 9 05-07-2012 09:50 AM
another pedestal rocker adjustment thread 73 fourxfour 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 38 02-20-2011 03:55 PM
bent exhaust valves? 73 fourxfour Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 07-09-2010 02:08 PM
302 Valve train questions. PLENTY OF INFO a truck named effy 1973 - 1979 F-100 & Larger F-Series Trucks 7 06-28-2010 04:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
