$160 bellowed up pipes?
Old 11-25-2013, 09:07 PM
RavageX's Avatar
RavageX
RavageX is offline
Found these while looking for parts to fix my truck. Thought I would share as the price is so low compared to what I have seen.
Dorman 679-005 Exhaust Manifold Crossover Pipe : Amazon.com : Automotive Dorman 679-005 Exhaust Manifold Crossover Pipe : Amazon.com : Automotive
Old 11-25-2013, 09:13 PM
HKusp's Avatar
HKusp
HKusp is offline
That's a good price even on the doormans. The lowest I have seen them for was $192.
Old 11-25-2013, 10:26 PM
sand_fiend's Avatar
sand_fiend
sand_fiend is offline
I need new up pipes.. i have been looking at the IH up's.. are the dormans good ??
Old 11-25-2013, 10:34 PM
ebbnflow's Avatar
ebbnflow
ebbnflow is offline
I had to send my Dorman uppies back 2 times because the collector which is cast iron was bad. 1st one had a hole in it, 2nd one had a large pit on the mating surface. The third time was the charm, it was perfect.
Old 11-26-2013, 06:40 AM
HKusp's Avatar
HKusp
HKusp is offline
I have heard that their quality leaves a little to be desired, but that they are passable usually. I hadn't heard of anyone having to send them back before ebbnflow mentioned it. I did hear of people having issues with the recessions for the bolts being too shallow and the castings being a bit rough, and maybe needing some dremmel work or some grinding to make them a little smoother flowing, but they are decent enough to work.
Old 11-26-2013, 10:59 AM
trekbasso's Avatar
trekbasso
trekbasso is offline
If I remember there was a lot of discussion earlier in the year, if not late last year. Yes the quality wasn't IH but they seemed to work??
Old 11-26-2013, 11:03 AM
lartross's Avatar
lartross
lartross is offline
I recently installed dorman up pipes and the baby's butt was good and the bolt holes were bored and tapped all the way thru. It was a pain in the rear to do tho...
Old 11-26-2013, 11:12 AM
trekbasso's Avatar
trekbasso
Yes, a giant PITA. But, harder using stock pieces from Ford, and I still spent over 300 bucks doing mine because of broken bolts, broken easy outs (ha ha) and buying new collector. Go bellows no matter whose you use.
Old 11-26-2013, 01:47 PM
RavageX's Avatar
RavageX
RavageX is offline
Buying these now, hope they are good. Even if they only last 5 years, 2 sets would be cheaper that 1 set of IH ones.
Old 11-26-2013, 02:18 PM
th67ss's Avatar
th67ss
th67ss is offline
Post back when you get them, and let us know what you think. I need to do this and I've been going back an forth between these and IH's.
Old 11-26-2013, 02:37 PM
Jesser02EX's Avatar
Jesser02EX
Jesser02EX is offline
I bought and installed the Dorman Up Pipes earlier this year. Currently I have severl thousand miles on them and they are holding up good. I collector didn't have any issues and locked up tight. I have checked them several times and they are performing just as needed. I got mine from Advance Auto parts for $148 shipped. Best deal ever!
Some have big issues with them, but I and several others have had great success.
Old 11-26-2013, 08:28 PM
jps47's Avatar
jps47
jps47 is offline
advanced coupon code trt30 for 30% off up to $50 max discount get them for 143 shipped. discount works on anything till end of tomorrow internet only.
Old 11-26-2013, 09:07 PM
sand_fiend's Avatar
sand_fiend
Ok, i ordered the dorman kit. My pipes have been leaking.
I use to get about 25 lbs of boost with the tuner, exhaust and 6637.
Now im under 20, and there is soot on the firewall.
The bolts are froze. tried to tighten them up with no luck.
I still have my turbo o-ring set with the bolt's from when i bought the master o-ring kit from diesel o-rings.
So who want's to try and talk me out of installing them my self !! anyone... anyone.... LOL
Anyone have a link on the replacement of the up pipes and what i will need ?
Used the trt30 and got the $50 off $143 + tax
Old 11-26-2013, 09:48 PM
Jesser02EX's Avatar
Jesser02EX
Do a search for Diehardstroker. He did a great write up and I did the job while he was doing it. I had an easier job due to no rust, but he did the write up and pics. Since you will need to pull the turbo, might as well rebuild the turbo and change the wheel if you have been thinking about it.
If you have leaking I/c boots, change those too. If you have a leaks in your EBPV, rebuild or delete it. Repair your passenger side fuel line if it's rubbing on the mount and check the UCVH and glow plugs. You will already have it torn down.
Just a few suggestions from someone who has rebuilt the top end.
Old 11-27-2013, 05:29 AM
lartross's Avatar
lartross
lartross is offline
Yeah, I rebuilt my turbo and pedestal while I was in there and had already done boots, uvch and glow plugs. In fact, the only things I haven't done on my truck so far is driveline and transmission. Driveline is next...transmission will wait for awhile...maybe another 80 to 100 thousand miles...presuming it lasts as well as others seem to have.
Quick Reply: $160 bellowed up pipes?
