My 1983 F-250 project.
#92
#93
#95
Got the NV4500 out today. Inside wasn't as bad as I was thinking but the dam case is cracked from the idiots cutting corners putting it together last time they "fixed" it.
Input shaft bearing was gone.
Well I pulled the rest of the trans apart. I fought 5th gear for over and your to get that dang thing off. Everything else looked great inside the transmission though. I'm pretty sure this had a 241DLD behind it. Does anyone know if the input shafts are interchangeable from the 241DLD and the 241DHD? I have that 241DHD behind the 47rh that will accept a speed sensor. I'd like to use it since my 10.25 rear doesn't have one.
#96
#97
#100
#104
The last parts for my transmission came in last week. The 24V is the same length as the 12V so figment should not be an issue. I also swapped tail shafts on my transfer case to give me a speed sensor. I pulled the seats out cleaned them up as well. I'm back to working 70+ hours a week so not much time to work on it.
