Heading to Harry's - What to Grab?
on
1 Post
Me too. I've been using those for years. My daughter just snapped Tyler's driver door handle off yesterday. He had two of the metal handles over here at my shop we been saving for his truck, so he will be putting them in his. I need to hit some junk yards and find four of them for Big Red.
Brand new Bosch superduty diesel pumps are cheap.
They are inline on the frame rail, gas trucks have pump in the tank.
Harry's cycles through cars regularly so you gotta get up there every 4-6 weeks to get good picking. They crush 4-6 rows every month. I went up there on one day, two days later I went to get a 4.6dohc motor... Crushed.
3 months later, went up and found a v10, went up 3 days later... Yup, crushed.
I have bad luck.
I suggest you try your best to get what you want right when you see it.
I have bad luck.
No they are NOT. They just brake the door. If anything, you want to grab the Linkage from those doors and replace the cable in the 92-97 doors but NOT the metal handle
I like the idea of metal rather than plastic and I like to think i'm pretty gentle on things like that so maybe i'll go for it.
thanks for the suggestion, Bill.
I have bad luck.
I have bad luck.
and yes, they do go things quickly there! I've got a prioritized list i'll be going in with. whatever I can grab in ~ 2-3 hours (maybe less depending on the temp that day and numbness of fingers) will be it!
I always find that the $2 admission fee is money well spent even if I don't come home with anything. its quite entertaining to see all those old trucks in one place and all the people that come to get parts - like me!
The issue with the metal handles that Brad is referring to is that guys will break 2 or 3 plastic handles because they're yanking away trying to open the door when the linkage on the handle or the cable is shot. So instead of replacing the plastic handle and the linkage they will see these metal handles as the solution and put them in....then they break the metal part of the door where the handle bolts on because they never addressed the original issue. But I guess if some gorilla got into the truck and was way too rough with the handles they could break the door, so in that regard Brad is correct. I just like the metal handles because they look and feel better than the cheapo plastic handles that came stock. I like them, so I (and apparently Bill and several others) run them!
X2 Big time on the driver door panels, Even if the driver door panel is shot, check to see what the trim piece that goes around the window switches is like, thats another high value item
good call on the go-pedals. they're easy. I def grab them off of any/all OBS powerstrokes I can find. ...and then post them for sale on here for $100/each
...just kidding. $99.99 :-)
ok, just kidding again. if I do find any, i'll keep one as backup for myself and let you all know for anyone who's interested.
prob won't have time to pull injectors, but that driver's CC door panel is a great call - I completely forgot about all the extra switches that would be in that panel!
as for the cupholders, OSU - I've never even seen them, so I don't know what to look for, but i'll definitely keep an eye out!
#29
They look like this
http://images.gtcarlot.com/pictures/54996741.jpg
#30
