Heading to Harry's - What to Grab? - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-26-2013, 08:59 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Quote:
Originally Posted by ReBilld View Post
JP, if they have any '80-'86 model trucks, grab the metal interior door handles. They are a good upgrade to our plastic ones......right Nate..
Right you are, Bill! Right you are! It's the little things that do it for me, lol.
Old 11-26-2013, 09:04 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Me too. I've been using those for years. My daughter just snapped Tyler's driver door handle off yesterday. He had two of the metal handles over here at my shop we been saving for his truck, so he will be putting them in his. I need to hit some junk yards and find four of them for Big Red.
Old 11-26-2013, 09:05 PM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Brand new Bosch superduty diesel pumps are cheap.
They are inline on the frame rail, gas trucks have pump in the tank.
Harry's cycles through cars regularly so you gotta get up there every 4-6 weeks to get good picking. They crush 4-6 rows every month. I went up there on one day, two days later I went to get a 4.6dohc motor... Crushed.
3 months later, went up and found a v10, went up 3 days later... Yup, crushed.
I have bad luck.
I suggest you try your best to get what you want right when you see it.
Old 11-27-2013, 05:55 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
No they are NOT. They just brake the door. If anything, you want to grab the Linkage from those doors and replace the cable in the 92-97 doors but NOT the metal handle
Old 11-27-2013, 08:04 AM
The metal handles are fine as long as you're not putting them on the door because you keep breaking the plastic handles. It's not a solution to a bombed out linkage or a stretched cable, they just feel better than that stupid cheesy plastic handle does.
Old 11-27-2013, 08:09 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
Quote:
Quote:
some differing opinions, I see. :-)
I like the idea of metal rather than plastic and I like to think i'm pretty gentle on things like that so maybe i'll go for it.
thanks for the suggestion, Bill.
Old 11-27-2013, 08:12 AM
I have bad luck.
good point about new pumps being cheap. maybe i'll grab just the mounting bracket off a diesel if I find one, but I don't expect to see any diesels in the yard anyway.
and yes, they do go things quickly there! I've got a prioritized list i'll be going in with. whatever I can grab in ~ 2-3 hours (maybe less depending on the temp that day and numbness of fingers) will be it!
I always find that the $2 admission fee is money well spent even if I don't come home with anything. its quite entertaining to see all those old trucks in one place and all the people that come to get parts - like me!
Old 11-27-2013, 08:25 AM
The issue with the metal handles that Brad is referring to is that guys will break 2 or 3 plastic handles because they're yanking away trying to open the door when the linkage on the handle or the cable is shot. So instead of replacing the plastic handle and the linkage they will see these metal handles as the solution and put them in....then they break the metal part of the door where the handle bolts on because they never addressed the original issue. But I guess if some gorilla got into the truck and was way too rough with the handles they could break the door, so in that regard Brad is correct. I just like the metal handles because they look and feel better than the cheapo plastic handles that came stock. I like them, so I (and apparently Bill and several others) run them!
Old 11-27-2013, 08:41 AM
osu711 osu711 is offline
osu711 is starting off with a positive reputation.
You said you were looking for creature comforts, maybe look for some of those cup holders that mount on the seats, they are pretty hard to come by, at least by me
Old 11-27-2013, 09:00 AM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Go-pedals. PCMs/IDMs if they're cheap enough. Injectors, for cores, if they're cheap enough. CC XLT driver's door panels, if in good shape and space allows. Overhead consoles from other vehicles.
Old 11-27-2013, 09:12 AM
Quote:
X2 Big time on the driver door panels, Even if the driver door panel is shot, check to see what the trim piece that goes around the window switches is like, thats another high value item
Old 11-27-2013, 09:26 AM
good call on the go-pedals. they're easy. I def grab them off of any/all OBS powerstrokes I can find. ...and then post them for sale on here for $100/each
...just kidding. $99.99 :-)
ok, just kidding again. if I do find any, i'll keep one as backup for myself and let you all know for anyone who's interested.
prob won't have time to pull injectors, but that driver's CC door panel is a great call - I completely forgot about all the extra switches that would be in that panel!
as for the cupholders, OSU - I've never even seen them, so I don't know what to look for, but i'll definitely keep an eye out!
  #28
Old 11-27-2013, 11:35 AM
DarkStarMedia DarkStarMedia is online now
DarkStarMedia is gaining momentum as a positive member of FTE.DarkStarMedia is gaining momentum as a positive member of FTE.
let me know if you see any pontiacs from 67-74 with a 400 ci motor... been looking for a good core for more than a year...
richard
  #29
Old 11-27-2013, 12:19 PM
They look like this
http://images.gtcarlot.com/pictures/54996741.jpg
  #30
Old 11-27-2013, 12:37 PM
Quote:
richard
You do realize he is in PA and you are in AZ?!?!?
How do you remove a broken easy out?? hrdrckgld Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 08-14-2014 11:49 PM
New (to me) Excursion slowlanemcvane Excursion - King of SUVs 18 06-20-2014 04:21 PM
New (to me) Excursion! slowlanemcvane Washington Chapter 3 06-16-2014 09:28 PM
93 F Series (lack of) Grab Handles Blane 1987 - 1996 F150 & Larger F-Series Trucks 19 01-30-2004 08:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
