Engine knock at idle.
I have a 01 F-250 w. a v10 that used to have an engine knock/slap at idle that was louder cold than at oper. temp. I just thought it was a worn pin and/ or piston(engine has 230,000 + miles). So it comes time for a plug change (every50k since new). Changed the plugs and the noise dissapeared. Any ideas on why? All the old plugs came out fine and looked normal. Except for the back driver side. It seemed not quite tight enought w. resistance. I worked the plug back and forth w. penetrant and couldnt see any aluminum on the treads.Plug looked like the others.
Well the weird part is it had been making noise for about 1-2yrs, started faint and progressively gotten worse. I pretty much had gotten used to it and didnt worry too much becuase it went away when the engine warmed up.I checked my maint. log and 2 yrs was about 30k miles ago.
slickoneuk
1997-2006 Expedition & Navigator
02-08-2013 04:42 PM
