Full synthetic 75W140 vs 85w140 conventional?
I went to town the other day to buy some gear lube to change out my rear diff oil. They didnt have any strait synthetic 75w140, but had 85w140 conventional. They both show the same API service rating of GL-5. Does it really matter if I run the 85w140, as long as I fallow the service intervals for a conventional gear oil?
I'm honestly confused by the gear oil too. From what I understand, you need friction modifier in there for a LSD (typically the rear diff but not the front). Some synthetics come with friction modifier. If your oil doesn't have friction modifier in it, I think you need to add some.
Don't take my word for it but I would do more investigating on this quickly before you possibly damage your rear diff with conventional oil with no friction modifier.
That's why I mentioned changing over to the conventional oil service interval too. I pull heavy with this, and drop the oil yearly in the diff, needed or not.
I think that right there is why synthetic is recommended. Because alot of people just drive. Same can be said for the antifreeze used now vs the regular old green stuff.
Synthetic can handle a lot more stress than conventional.
Can also get a lot hotter and still maintain its function.
I don't know. how much would you save on regular v synthetic?
oh, and I am not a synthetic all guy at all. I use what ford recommends for the engine which is a synthetic blend.
But Ford does recommend synthetic for the differential.
I'm not looking at this so much from the conventional vs synthetic. That argument goes on for ever. I'm thinking about Ford's requirement for or suggested use of friction modifier. It stops the clutch chatter, which to me means, things will wear better. I also know you can add too much friction modifier, say for example, by adding it to a synthetic oil that already has friction modifier.
Guess I'm looking at it this way, I've got aftermarket gears and bearings in the diff, same gears and bearings they use from 92-04 10.25s and 10.5 rear ends. In 92 they ran 80w90, what makes this rear so special that it needs he 75w140 synthetic, expecially since it has 10.25 gears and bearings in it?
I understand synthetic has a lower pour point and what not, but, will it REALLY hurt the diff running a conventional oil? P
on
I wouldn't worry about having conventional oil in it, they have been using it for 80+- years with no problem and they have established that the synth oil will work well EXTREME temperatures but other than that the benefit is still controversial and therefore must be almost the same quality. I wouldn't worry about it myself. (Notice they both a a GL-5 rating). Also, all this hoopla about different gears and years etc means nothing, it is still just a rear end........come-on.
First, why is everyone jumping on the LS bandwagon when you never mentioned it.......lol
I was thinkin the same as you, it's a rear end... What's it care whats in it. I wanted someone with some experience in this subject to chime in.
O, and I do have a LS, but that's a mook point, both oil types need the modifier in it.
on
I was hoping you would see this thread.
Steve_Uzi
02-16-2012 08:44 PM
bryyce62
1999 to 2016 Super Duty
02-27-2008 05:35 PM
