AIM/Chassis Tech/Airbagit.com beam nightmare...Just my luck.
I've posted this on another forum if you'd please follow the link. I've never heard of this problem. Any ideas?
332-428 Ford FE Engine Forum: Just my luck........
i bought djm beams because all i read are horror stories abou the aim beams, stupid question but are you sure they are on the correct side? the kingpin angle is pointing aft at the top of the king pin right?
sorry if you already checked this, good luck im sire youll get it!.
matt
matt
Tomorrow I'll remove beams and set one of top of the other to check bends. The difference has to be from the radius arm mount outwards. No instructions included and hardware was wrong size.
Please keep n mind I am sharing info for DJM beams. Don't jump to any conclusions without talking to AIM first. The instructions that came with the DJM beams said to lay the beams on the ground and look straight down on them. The king pin should point rearward at the top when installed they said.
So while I think you should call aim, I feel that I'm right and you have two of the same side.
I just looked at my 65 and there is an obvious difference between left and right I beams. You will end up with a negative caster if you mix the two up.
I also measured the radius arms and the drivers side is 1/2" shorter than the passenger side.
My beams are out of a 76 and I used the stock 65 radius arms.
They were on the correct sides. You want the kingpins leaned back on top. They can only go one way to do so. The one pictured on the right is the driver's side.
Am I wrong?
