advise please!
advise please!
As you can see, my new bellow is right up against the trans, again. I don't know what to do about it. I don't want another hole rubbed in it. Maybe I just got a deformed set of up pipes. I put a pry bar up there and just after putting a little pressure on it, I stopped. Didn't want to ruin my new bellow. Then I shifted my head back and towards the frame, I caught a little light thru there. I thought to myself, that's paper thin so what the heck, I went and got a piece of paper. I could push the paper thru and then doubled it up and couldn't push it thru. Its that close. What should I do, pry on it some, leave it alone, pull it and try to bend a little, drill out the mounting plate and egg shape the holes so I can move it over a hair. Instead of bolts I could use bolts with a nut from the bottom. There is room on the passenger side to move every thing over a hair. I hate to drill out the threaded holes but a paper thin clearance isn't enough, is it????
Yes, everything was tight.
I'm wondering about Jake, period!! I like your idea but for myself I'll either grind that down or ?? I'm having problems and Gabe and Darin aren't makes me believe I got a retarded set of pipes, LOL. How much clearance do you think I need Bill?
on
1 Post
Just enough so it doesn't touch. Loosen the bolts where the up pipe is bolted to the manifold. Tighten the top one first and see if it will draw the pipe enough to bring the bellow away from the trans, then tighten the bottom one up. This may not work, but worth a try before you pull it all out again. If it doesn't, then grinding a little on the trans case may be your only option.
Sounds like a plan Mike, I hope I can get my grinder in there, LOL
on
1 Post
Yeah, that's what I meant. Tighten the top one and it will kinda roll the up pipe over to that side on the rounded flange of the manifold. You don't wanna over do it and put the pipe in a bind, just enough to see if it will pull it away from the trans. Then tighten the bottom on down pretty snug. Like I said, it may not work, but worth a try before you pull the whole deal out again.
