advise please! - Page 2 - Ford Truck Enthusiasts Forums
advise please!
Old 11-24-2013, 12:23 AM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
Just a thought but it may be those pipes are sized with an engine on a stand without accounting for the transmission. Or maybe sized with a bell housing for a manual transmission. I have no idea of the differences between the manual bell housing and the E40D case. If any.
Old 11-24-2013, 12:32 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Quote:
Originally Posted by fordman67 View Post
im late to the party...i would either grind it,throw it through irates front window or send it to bill to be made the way irate should have in the beginning....lol
Oregon would be a long drive for just a few seconds of satifacton, LOL I'll probably end of grinding it.
Quote:
I'm just thinking that I got a bum set of pipes Pete. IDK I bet Bill can answer that question about bell housings.
Old 11-24-2013, 06:30 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
I'd grind for room and not think twice about it Glenn. Like Mike said, 1/8 inch or so of clearance.
Old 11-24-2013, 09:11 AM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Just a caution. If you're going to use a grinding wheel be careful. Aluminum can load the wheel and cause pieces of the wheel to fly off. If you have beez wax you can cost the wheel with it to stop it from being loaded.
Old 11-24-2013, 09:32 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Now you have me worried. I'll have to look at my pipes today
Old 11-24-2013, 10:43 AM
Quote:
If Bill's idea doesn't work, I'll grind it. I just hope my grinder will fit.
Quote:
I've never heard of that Mike, seems like the heat would melt it off. Safety glasses time!!
I still get a kick out of your signature, grandpa package, LOL That cute boy of yours will be chased by all the girls and you will be a grandpa before you know it.
Quote:
What kind of up pipes do you have Brad?
Old 11-24-2013, 12:36 PM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
After a little more of an inspection I notice the top part of the bellow rubs on my trans. If it was cut out and moved down a half inch it would fine but it's running on the top "rib".
Edit: It's kinda hard to get a kindle up there for a close up
Old 11-24-2013, 01:49 PM
Thanks Gabe, maybe my up pipes aren't bad, its just a bad design like Bill says. The bottom part of my bellows is the problem area.
Old 11-24-2013, 04:10 PM
rodneywar's Avatar
rodneywar rodneywar is offline
rodneywar has a good reputation on FTE.rodneywar has a good reputation on FTE.
I think it is a bad design as well the turbonetics bellows are right below the collector
Old 11-24-2013, 05:13 PM
Thanks for the suggestion Bill, it worked!! In this picture you can't tell because there is a flange or something in the way at the bottom but its clear of the trans now. I don't think I need to grind any thing. Actually, looking at my picture again, what you see at the bottom is in the background. Once I pulled it over with the top bolt and tightened it down, I then tightened the bottom bolt but not as tight. While I tightened down the bottom bolt I had a pry bar stuck in there just in case it wanted to move.
Old 11-24-2013, 05:17 PM
fordpride's Avatar
Glenn I have a 4" scar on the right side of my belly where a disk blew and sliced me open.
I was grinding on an aluminum bike trailer.
The aluminum clogs up the disk on over heats it.
Old 11-24-2013, 05:52 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Looks good Glenn, how much clearance did you end up with then?
  #28
Old 11-24-2013, 06:06 PM
I know you were giving me good advice Mike. I have seen them get clogged and hot. Ouch, that got your attention.
Just guessing Nate because it such a hard place to see, I would say just 1/8". I think its good to go, I think the pry bar was helpful also, it looked like it wanted to go back as I was tightening down the lower bolt.
Gabe, I would try that before yours rubs thru. I only took a few minutes.
  #29
Old 11-24-2013, 07:57 PM
pjwoolw's Avatar
Good deal Glenn! Glad that worked out for ya!
Atta babe to Bill!
  #30
Old 11-24-2013, 08:11 PM
Quote:
I have Irates and mine is a stick so I have even less room
err... umm... you guys know where I can find my buddy a door for a 2012? Christof13T 2009 - 2014 F150 12 08-25-2014 03:41 PM
I think I'm running out of oil!! oldbird1965 1994.5 - 1997 7.3L Power Stroke Diesel 51 03-17-2014 10:21 PM
really, really OT 5er rear camera oldbird1965 1994.5 - 1997 7.3L Power Stroke Diesel 9 01-24-2014 09:19 AM
Turbo whistle almost went bye-bye! oldbird1965 1994.5 - 1997 7.3L Power Stroke Diesel 31 01-22-2014 11:08 PM
40psi and quiet! oldbird1965 1994.5 - 1997 7.3L Power Stroke Diesel 146 12-28-2013 09:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
