I have a 48 f2 I am working on. And I don't know how to remove the gas tank.
Are the bolts on the bottom (I don't see them)? This is not welded in is it, I really hope not.
The same two bolts that attach your "holder thing," more commonly called a tool tray, will also retain the gas tank. Remove the bolts and disconnect the fuel line from underneath and you're free.
Okay just to clarify , the 2 bolts inside the tool tray both retain it and clamp the fuel tank down in place . The only other concern is the fuel line .
Be carefull wth the tooltray. If its got stuff in there the bottom mite be rusty and you'll blow a hole in it.with the washer.Not to mention blowin' that stuff all over which will give you more to clean up.
