Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Old 11-23-2013, 01:15 PM
Firefighter 1406's Avatar
Firefighter 1406 Firefighter 1406 is offline
Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.
AWD not working. Direction needed.
Okay the problem is my AWD in my 98 Ford Expedition doesn't work. When shifted into AWD in starts flashing. The 4HI does work but it will not shift on the fly. You have to come to a complete stop to get 4H to work. 4L works like it's supposed to. I have read the post on this problem. Shift motor is working, took it off to confirm. From actuator is also working. I have read that the sensors in the transfercase could be the problem. My transfercase has 2 of them. Are they both the same sensor just checking different things? Do I have to replace 1 or both to fix my problem? Have also heard that the speed sensor on the rear axle could be the culprit.
The part number for the sensor on the transfercase is 1L2Z-7F293-BA. About $50.
Does anybody have any further info on what these sensors do and how to fix?
It's my wife's truck, and would really like the AWD and the 4wd to work the way it's supposed to.
__________________
Seth "WE WILL NEVER FORGET" 343 PAA#129
Not so Early 99 F-250 Super Cab 4X4 w/7.3 stroker w/ 260,000, 6637 filter, 4" MBRP turbo back, coolant filter, zoodad, Hx, AutoMeter Guages, AIC, Leveling kit, Warn Premiums, 285 Duratrac's, Firestone Air Bags, Rancho 9000 XL's, Strobes,
www.roadsidehelpnetwork.org/
Old 11-23-2013, 01:21 PM
alloro alloro is online now
alloro is a name known to allalloro is a name known to allalloro is a name known to allalloro is a name known to allalloro is a name known to allalloro is a name known to all
I agree that it's probably one of the transfer case sensors. Judging from the fact that you cannot shift on the fly but can when stopped, I suspect the front sensor, or it's circuitry is the problem. If the rear sensor was the problem, then the speedometer wouldn't be working.
__________________
To thank someone, click the left red "Add to Reputation" button
right of the word "permalink" top right of the poster's message.
Old 11-23-2013, 09:19 PM
Okay. Where is the rear sensor mounted. To the left of the transfer case motor or to the right? I can't quite remember how they are mounted. Are both sensors the same part number?
__________________
I appreciate the post. 85 views and 1 post. I was getting nervous.
__________________
Old 11-23-2013, 10:17 PM
Quote:
Don't sweat it, sometimes it can take days for people to respond. I've attached PDFs of the repair manual pages for the front and rear speed sensors. They should help you to locate them.
__________________
Old 11-23-2013, 10:33 PM
Thanks. That's awesome. I appreciate your help. Do you know if they are the same part numbers?
__________________
Old 11-24-2013, 01:46 PM
I believe they are, but I am not 100% certain. I'm more like 90% certain.
__________________
Old 11-24-2013, 08:29 PM
I appreciate it. Have to get this done.
__________________
Old 12-24-2014, 04:11 PM
Old thread but I found it. Alright got the sensors fixed. AWD stays shifted in now and doesn't flash anymore. Still will not shift on the fly into AWD or 4H. I know my actuator motor is working. And last time I checked my front axle actuator was shifting also. I am at a loss.
__________________
Old 12-24-2014, 07:41 PM
Between the 2 or from low?
__________________
Old 12-24-2014, 08:40 PM
From 2H it will not shift into 4H or 4L.
__________________
Old 12-24-2014, 09:16 PM
You have to be stopped and in neutral to shift in or out of low. But 2H to 4H or A4WD should happen at any speed under 65 MPH. Can you shift between 2H, 4H, and A4WD when stopped?
__________________
Old 12-24-2014, 10:15 PM
Quote:
As long as I am stopped everything works great. Just no shift on the fly.
__________________
Similar Threads
Awd binding noise during sharp turns jmmranger Expedition & Navigator 16 06-19-2014 09:48 AM
4x4 shifting problems Firefighter 1406 Expedition & Navigator 5 12-02-2012 12:11 AM
2000 Expedition rumbling noise on takeoff 1963f100 Expedition & Navigator 2 01-25-2008 04:27 PM
AWD/4WH/4WL Selector Switch amkazen Expedition & Navigator 9 09-03-2005 03:17 PM
transfer help Ezra Clutch, Transmission, Differential, Axle & Transfer Case 1 10-11-2002 09:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
