Building onboard air system - anyone have parts? - Ford Truck Enthusiasts Forums
Ohio Chapter Join Chapter, Leader: RUNVS
Old 11-23-2013, 08:59 AM
RUNVS's Avatar
RUNVS RUNVS is offline
RUNVS has a good reputation on FTE.RUNVS has a good reputation on FTE.
Have had my truck for a long time but after looking at the cost to replace...I think I am going to hold on to her for awhile longer.
One of my planned projects that I am currently gearing up for is an on-board air system. I have recently purchased a used Viair 450c compressor for a great price. I'm in search of other items now and thought I'd see if anyone around here has anything.
Anything that would go with an onboard air system; fittings, flexible air lines (150psi+), tank, etc.
I already have my horn on my Christmas list but if anyone just happens to have a Grover 1510 they'd like to let go, hit me up!!
I also need to do a crap-ton of wiring on this truck for the upgrades I am in the process of and the planned future add-ons. If anyone has spools of wiring let me know.
Old 11-23-2013, 09:18 AM
coolbluef150 coolbluef150 is offline
coolbluef150 is starting off with a positive reputation.
I don't have any air system parts, I do have some wiring ......bit I do have lots of tools and an eagerness to help a brother out.
Old 11-25-2013, 01:19 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
Plastic line? I get that at Cross truck parts(actual DOT rated line). Any "big rig" parts store has that it at minimal cost/foot. The brass fittings are also in the same place.
I'd check around truck junk yard for a tank. I think I had less then $35? each for the two tanks I put on my Mack when I stretched the frame and put air ride on it. They were just take offs, even had mounting studs installed on them for easy installation.
Horn? I have one spare horn, don't know the part number. It is a matching unit to the single I have on my truck. Just was waiting to find the front support arm before I try to put it on my truck. There again, truck junk yard is best place.
I used a little yard here in Barberton for all my stuff. Really reasonable prices compared to some of the big yards(like Adelmans in Canton).
Old 12-03-2013, 09:21 AM
RUNVS's Avatar
Figures, I was just down that way a week ago - the night you made that post!!
Is the plastic line rated for 150psi? I would imagine a tank from a Mack would be too big for the Superduty. I have seen guys put up to 5 gallon but I need to find that "right fit" size tank for the compressor.
The 450c is 100% duty-cycle and I think a 2-3 gallon tank is about right for what I need.
I found a 2.5 gallon Viair tank for about $65 new, shipped. I just put the horn on my "list for Santa" and handed that to the wife, LOL!!! I really want a stuttertone horn, not a train horn which seems to be all the rage right now. I'm not going to drive around the mall scaring teenagers but I want something with authority!
Someone on here mounted their compressor in an ammo box and I love that idea!! There is a gun shop nearby that has lots of old ammo boxes so I will stop in there and find one that fits the size for this compressor.
Old 12-03-2013, 09:24 AM
RUNVS's Avatar
Hard to tell scale, what size are those tanks? I would guess 5-7 gallon?
Old 12-09-2013, 04:02 PM
Shiftoholic
6-7" round? about 24"-30" long? Something like that. Have to actually measure them to see.
Pretty sure all the DOT line is rated for 150#, as it has to deal with brakes and you know they would not allow it if it was marginal. Most any big truck has 120-130# high side shut off for compressor.
Old 12-11-2013, 10:30 AM
RUNVS's Avatar
7" Dia. x 30" long would be about 5 gallon, I believe. I have no idea how to match up the compressor size to the tank size. However, most of the time I see a 450C compressor it is matched to a 2.5 or 3 gallon tank. I am sure it would fill five gallons but just take a lot longer to do so. It is a 100% duty-cycle so it could run continuously until filled.
Old 12-13-2013, 12:36 PM
Shiftoholic
Not like you have constant use for the air, so the pump would not have to run forever. I don't know what the compressor looks like, but on my Mack it takes a 1-2 minutes to fill one tank with motor idling(like a cold start up after a week sitting). Don't know what the CFM rating is? Looking up your compressor it is .9 CFM at 100 psi. Not alot of volume(but who needs it).
I'd go with a bigger tank if possible. You can always use it for filling a tire? changing a flat(with air gun). Whatever. Mount it longways along outside the frame under the bed.
Old 12-16-2013, 11:43 AM
JOHN2001's Avatar
JOHN2001 JOHN2001 is offline
JOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to behold
With my air horns I ran a 2 gallon tank mounted to the inside of the hitch then took my air compressor and mounted that tucked up inside the x bracing of the spare tire welded to the frame ( all seemed like the safest place for everything). For pump to tank piping I used a ss braded line with swage lock fittings. I forgot what kind of hose I used for the tank to horns it was just a rubber hose I'll look at it if you need me to.
I took all that stuff off and it's sitting in the garage waiting for a revised version of my tank that I'm making. I have 4 - 3" ss pipes welded in parallel 30" long that I'm going to be putting on as my new tank when I get around to finishing. I may add one more piece of pipe to that. I'll hook up my air horn again but am going to add a line with a T and split the line to come out mid way on each side of the truck with quick disconnects and put a short air hose in the cab of the truck along with an impact. This way if I get a flat and I can hook up the impact and or air chuck to fill up or change my tire.
ONBOARD AIR COMPRESSOR johnsjsj 1999 - 2003 7.3L Power Stroke Diesel 15 03-07-2013 11:44 PM
ONBOARD AIR COMPRESSOR johnsjsj 1999 - 2003 7.3L Power Stroke Diesel 26 09-13-2012 09:22 PM
Anybody added on-board air? Robert6401 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 11 02-25-2012 09:53 AM
On-board Air A/Ox4 1999 to 2016 Super Duty 4 06-06-2011 03:34 PM
AC Compressor / On-Board Air billrigsby Offroad & 4x4 21 03-29-2004 08:50 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
