P0672 Cyl #2 GP Circut...
I got code P0672. I checked on the interwebs and found that most other cases of this code are typically paired with other codes. Can anyone lend me some advice as to whether or not I should replace other parts that are probably going to go soon as well. Stranded in winter is not where I want to be.
Thanks in advance,
John
Thanks in advance,
John
I have the same thing but on #6.
No other codes.. last I checked.. and only other symptom is lots of white smoke on cold starts.
I have replaced all 8 glow plugs and didn't fix the problem. Went through all of last winter with this issue, thinking I'd get to it in the summer but it's already winter again...
Any ideas would be great. If it's easy enough, I might even do it this winter.
Sent from my Galaxy Note 3 using IB AutoGroup
https://www.ford-trucks.com/forums/8...ml#post7885088
95PSDNewbie
04-23-2016 05:15 PM
goosehunta
01-22-2012 08:00 PM
