What are these intake manifold tubes?
Old 11-22-2013, 07:17 PM
wolfpackfan94's Avatar
wolfpackfan94
wolfpackfan94 is offline
1974 F100 460
And do I need them? One I think is the old hot air choke and one goes hooks to the carb via a vacuum line. As you can see the carb has an electric choke and (what I think it is) the old hot air choke tube attached to the choke.
Could I eliminate these and is there a block off plate that could replace the plate with the two holes in the intake manifold.
What does the line that goes to the carb vacuum port do?
Old 11-22-2013, 08:12 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
That's a choke heat tube...AKA hot air choke tube.
Are you subject to emissions testing?
Old 11-22-2013, 09:25 PM
wolfpackfan94
No emissions testing required in my state due to age.
What is the second tube beside the hot air choke that has the vacuum line to the top of the carb?
Old 11-22-2013, 09:34 PM
devino246's Avatar
devino246
devino246 is offline
On the stock setup, one tube ran up to the top of the carb and sucked in fresh air while the other ran through the choke cap and ultimately accessed a small vacuum port. Air was pulled from the top of the carb, down into the manifold where it heated up, into the choke cap where it heated a bimetal spring, and then ran through a small hole in the carb which sourced manifold vacuum for air flow.
Old 11-22-2013, 09:37 PM
wolfpackfan94
So I could eliminate them now? Is there a block off plate of some sort?
Old 11-22-2013, 09:41 PM
devino246's Avatar
devino246
Yeah, you don't need it with that Holley choke. There aren't any block off plates that I'm aware of, though it wouldn't be hard to make one of your own.
Old 11-22-2013, 09:53 PM
wolfpackfan94
Maybe pull the tubes out and put a couple of screws in the two holes of the current plate.
Old 11-22-2013, 10:02 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
Please refer to the following thread:
https://www.ford-trucks.com/forums/8...-answered.html
FuzzFace2
09-18-2018 12:18 PM
46Whizzer
01-08-2015 12:07 PM
arnegrant
04-02-2009 01:32 PM
76 F250 4X4
09-20-2004 12:12 AM
Big Red
12-17-2003 08:33 AM
Quick Reply: What are these intake manifold tubes?
